PostPosted: February 8th, 2019, 9:36 am
I just bought the XLaunchpad Pro application. It's a great tool and perfectly addresses something I have been looking for at work to demo and old application. The only challenge I am finding is that I would like to disable the right click menu options after setting up the presentation and arrangement of the icons. I don't want others to be able to change it on the station after it has been set up a certain way. I was looking around in the registry on the off chance I might find something, no luck.
Can anyone help with this question?
Thanks
