 Post subject: I cant save settings
PostPosted: August 11th, 2015, 4:49 am
i dont know if this is a Win 10 problem, under win 7 X64 it works fine. Changes in my settings are no longer stored. Also the backup does not work anymore.
After restart my pc will load back the previous and not the new setting that i put.
 Post subject: Re: I cant save settings
PostPosted: August 11th, 2015, 6:58 am
The Windows10 is a new platform so it's logical that there are some bugs. We need to wait for an update...
PostPosted: August 14th, 2015, 6:35 am
Do you use a portable or a normal version?
PostPosted: August 17th, 2015, 6:41 am
Normal version 1.0.9.518
