It is currently June 14th, 2025, 8:08 am
Post new topic Reply to topic  [ 382 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: November 13th, 2013, 9:34 am
DOWNLOAD FREE: https://play.google.com/store/apps/deta ... ft.xwidget
DOWNLOAD PRO: https://play.google.com/store/apps/deta ... widget_pro
[Last version ChangeLog]
v1.7.2
XWidget Online gallery reached the 2000 widgets! To celebrate we offer all our Pro apps with 50% of discount for one week!
1.Add local language support for date time. Now you can set phone's language to the DateTime widgets AUTOMATICALLY and DIRECTLY with one option.
2.Support for Android 8.0
3.FAQ updated with more info about language options
4.UI edited to be more easy to find and download our apps.
5.Fixed Datetime timezone bug (multi-datetime cores used)
New version 1.6
1. Important Improve: Fix font memory leaks and greatly reduce memory usage
2. Important Improve: widget hotspots activated directly.
No longer need to click once to activate hotspots after adding widget
3. Bugs fixed for the calendar widgets
4. Added "TextFrame" option for the text component
5. General optimizations
New version 1.5
- Important Improve: Widget hotspots are now activated directly!No longer need to touch once to activate hotspots after adding widget.
(requires Android4.4+ to activate it because of the Android OS restrictions)
- Seconds for analog and digital clocks full support and optimization
(if you want animated clock widgets please try our new XAnimateClock app)
v1.4.0
2018-4-7
1. Bugs fixed for the calendar widgets:
- Position of the "Today Image"
- "Day offset" option
- Go to prev/next month loading data problem
2. Added "TextFrame" option for the text component
3. General optimizations
2017-11-10
Add PhotoAlbum Core,then we can create photo album widgets
Add FAQ form and menu
Fixed small bugs
2016-8-31
Added Search/Filter function for Online-Widgets-List
Fixed the bug of Widget Froze sometimes,etc: when update weather data
Fixed freezing time on some devices
Fixed other small bugs
UI improvements
2015-7-22 v1.09
Add: RoundLine/Circle/Line/Pie controls
Fixed: Weather data is not the right bug
Fixed: Menus display not right bug
2014-12-5 v1.071
Fixed: Image Scale not display correctly
Fixed: Crash when select some of widgets
2014-11-28 v1.07
Add: Globle CMD "!ChangeImgSrc=image1,bg2.png"
Fixed: Text control "Intercept" property not work bug
Improve: Clock not update when XWidget process killed by some "Kill processes" or "Release memory" app
Improve: Weather "Auto location" sometimes delay update
2014-8-23 v1.06
Add: Weather option "Always auto location",re-location every time update weather
Fixed: Weather can not auto location problem on some phone
Add: Auto update weather info when network connected
Improve: Widgets list auto load next page when scroll to end
Improve: Widget popup menu uses Whole Holo style
Improve: Improve Download widget UI,bigger preview image,Support the right slide gesture to back widget list
Add: Widget setting add option "Click Event/Action",you can make it open an App or never popup widget menu
Fixed: DatetimeCore tag "WeekOfYear" number less 1 than actual
Add: Support Admob banner,but you can disable all banners in widget list activity menu,NO PAYMENT IS REQUIRED! (Need permission of "DeviceID")
Add: New bug and problem submit activity
Fixed: Clock stop update on some phone
Fixed: Crash on some phone
2014-01-10
v1.03
Fixed: crashing on some phones
Fixed: app process not exist when widgets removed
Fixed: online widget list not auto refresh problem when select widget
2014-01-08
v1.01
Fixed: Crashed on android 2.3 problem
Fixed: Designer for Android controls size property limite problem
2013-12-28
v1.0
Add: XWidget Designer for Android,click menuitem "Edit widget" to launch
Add: New UI of HOLO Dark Style
Add: Widget list support catagary
Add: Shortcut Core
Add: Option "Disable all widgets menu"
Fixed: Weather widget set fahrenheit invalid when restart
2013-12-16 v0.999
Designer Beta
Add: shortcut core
Improve: local widget list change to 2 line each row.
ShortcutCore has tags: displayName , path , icon
action: showSetting, open/openFile
2013-12-10 v0.999
Add: XWidget Designer for Android,click widget menuitem "Edit widget" to launch
Add: Option in main window -- "Disable all widgets menu"
2013-11-7 v0.998
Add: Online widget list sort menuitem.
Add: DateTimeCore,WeatherCore add tag "dayOrNight",if day will return "d",otherwise return "n"
Fixed: Rotator control property "alwaysforward" not currect bug
Fixed: Widget list refresh some times crash bug
2013-11-17 v0.997
Add: local widget list add menu item "Sort by" ,include sort by datetimt, sort by title
Fixed: crash after download online widget and refresh local list
Improve: uses new XML parsing mode , up to 5x faster
Improve: reduce installation package size 30%
2013-11-16 v0.996
Add: Text control support FontStyle: Bold/Italic/Underline/Stikeout
Add: German, Hungarian Language
Fixed: Image control wrapmode-fit had beed stretched bug
[Screenshort]
XWidget is the Android version of the famous Free desktop customization platform "XWidget" for Windows.
A very lightweight and highly customizable widget engine with powerful visual widget editor.
[Feature]
1. Provides a new way to DIY widgets for Android.
2. Cross-platform widget: the widget you create on PC can run both on Windows and Android platform.
More than 1000 widgets created for PC can be used on your Android device or Tablet! You can search on the official XWidget or on DeviantART.
http://android.xwidget.com/
or
http://www.xwidget.com/xwidget/
or
http://www.deviantart.com/?order=5&q=xwidget
XWidget for Android Beta only support:
Image/Text/NumbImage/Rotator Controls, and DateTimeCore/WeatherCore/BatteryCore. We are developing more controls and cores.
3. All the widgets can be resized on Android 4.0+,otherwise you need custom launchers that support this function like ADW Launcher, Apex, GO Launcher EX, Nova etc.
4. Visualization widget designer for Windows PC: you can create your own widgets with XWidgetDesigner for Windows,and One-key to send the widget to your Android Device to preview or run.
5. Supports hotspots.
6. Runs on devices with old OS, Android 2.1+
7. Few resources taken: running the widget only needs 6-12M RAM, not using the CPU in peacetime.
8. Very lightweight and Battery Friendly: Do not run any code or action after lock screen , has no effect to the lifetime of the battery.
9. Online widget gallery: One-touch to download and install widgets from online gallery. Large number of widgets in online gallery, updated daily.
Long press to delete the widget.
10. Accuweather.com weather service for the weather widgets with up to 15 days forecast.
11. All the widgets use the original file extension ".xwp" of XWidget.
NO EXTRA ".apk" files are installed in your phone.
12. Requires only a few Permissions : only needs to write in external storage and access network Permissions.
13. Totally FREE and NO ADS.
Without any residual background services and processes: When closing the widget it will completely exit without any permanent backstage to slow down the system.
[Available sizes]
1x1, 1x2, 1x4, 1x5, 2x1, 2x2, 2x4, 3x1, 3x2, 3x3, 3x4, 4x1, 4x2, 4x3, 4x4, 5x1, 5x2.
[Note]
XWidget for Android Beta only support Image/Text/NumbImage/Rotator Controls, and DateTimeCore/WeatherCore/BatteryCore. We are developing to add more controls and cores.
[Tutorials]
How install widgets on Android phones: viewtopic.php?f=18&t=3776
[Permissions explained]
write external storage - to save and load widgets
accsess network state - for weather data and download widget from gallery
GPS/Location - for weather location
DeviceID - for GoogleAdmob
[Translator]
Geman by Dagedee
Hungarian by Szabó István
if you can help us to translate,please download this english lang file: http://sdrv.ms/1eZcXmW
[Special Thanks]
Jimking,Slavoo,QianCang,Digigamer.
[We need help]
--We need translators
--We need testers
--We need tutorial writers
--We need people to record video tutorials
If you had intresting,please PM me
PostPosted: July 3rd, 2014, 10:44 am
[Update log]
2014-07-03
v1.04
Add: Widget Settings add option "Click to open",support open App or not popup menu
Improve: Weather widget support GPS location
Improve: Location Widget list support paging and pull to load more
Improve: Widget list support widgets count
Fixed: Weather widget can not display Temp at some point
PostPosted: July 3rd, 2014, 2:58 pm
Not working.
I use this widget
viewtopic.php?f=11&t=4685
Nothing display
PostPosted: July 4th, 2014, 6:26 am
I just downloaded this from the Play Store yesterday and got v. 1.03. How can I get 1.40 to see if my issues have been resolved?
PostPosted: July 4th, 2014, 6:43 am
After test the v1.04 ,I will upload it to PlayStore.
Tony
PostPosted: July 4th, 2014, 7:09 am
Tony wrote:
vbhokiefan wrote:
I just downloaded this from the Play Store yesterday and got v. 1.03. How can I get 1.04 to see if my issues have been resolved?
Tony
Thanks! and thanks also, for such a quick reply! :D
PostPosted: July 4th, 2014, 10:40 am
I must admit that I am very disconsolate. I waited a long time for an update.
I could not wait. Unfortunately does not work. :( :( :(
Please Tony fix everything in 1.0.4 as in 1.0.3 in order to work.
PostPosted: July 5th, 2014, 8:22 am
The Android OS has so many versions and the apps depend also on the device.
The programming is not an easy task and don't forget that all start from a pc program and the port to Android is totally different. It happens that some times new features may break some old codes.. The difficult part is to make all work well. This is a rule for the Android OS in general, that is impossible make an app that will work 100% well for all the OSs and mobiles. And this is the stupid thing that Google very often gives new versions again and again and the apps loose their compatibility..
So pls be patient and I'm sure that Tony will fix the issues soon.. :)
PostPosted: July 6th, 2014, 1:11 am
OK, I will fix them soon :)
PostPosted: July 6th, 2014, 3:12 am
Thanks Jimking and Slavoo,
I had fix these 2 bugs,please re-download apk to test ,thanks :)
Download .apk file : http://android.xwidget.com/download2.php
PostPosted: July 6th, 2014, 3:25 am
hello, its possible to integrate also yahoo weather in xwidget?
PostPosted: July 6th, 2014, 3:38 am
Which widget? please post the URL or upload snapshot :)
PostPosted: July 6th, 2014, 4:09 am
Tony, he means if XWidget can provide weather from Yahoo, not only from Accuweather.com..
PostPosted: July 6th, 2014, 4:43 am
Oh,sorry, Can you help me to found Yahoo weather API? thanks :)
PostPosted: July 6th, 2014, 6:13 am
Tony wrote:
Oh,sorry, Can you help me to found Yahoo weather API? thanks :)]
But what about the weather icons/conditions and the compatibility??
The weather icons are made to match with the accuweather server (icon numbers,txt)
PostPosted: July 6th, 2014, 6:20 am
we can auto translate yahoo weather icon number to accuweather icon number
PostPosted: July 6th, 2014, 6:42 am
Download .apk file : oon.. :)
Tony, not working. I am android 2.3.6
PostPosted: July 6th, 2014, 6:54 am
What is not working? How do you operate?
PostPosted: July 6th, 2014, 7:43 am
Sorry Tony but read what I wrote. I wrote you earlier that all widgets are working on 1.0.3! This my kind of too big in your opinion, too. I have already forces. I'll use the 1.0.3. It is hard: ( Look at pm
Widgets display only background. Not working autolocation.
Ile razy mozna pisac to samo?
ALL WORKING on 1.0.3
Not working on 1.0.4
OMG!
Nie rozumiem, dlaczego u mnie nie działa :( :( :(
PostPosted: July 6th, 2014, 10:44 am
I found these pages:
https://developer.yahoo.com/weather/
http://www.programmableweb.com/api/yahoo-weather
PostPosted: July 6th, 2014, 11:16 pm
Later I had some time this will add screens with these problems. Will show you that my widgets and widget Jimking work on my 1.0.3 and 1.0.4 do not work on
Tony suggests that my widget is too large. But it does not matter if running on 1.0.3. I think that Tony introduced to limit the size, then you will have all the widgets remodel. : (
Still does not work autolocation GPS. Simply finds nothing.
Regards Tony and Jimking
PostPosted: July 6th, 2014, 11:26 pm
Hi Salvoo,
Can you help to found the CrashLog? etc: open folder "sdcard/XWidget/crash/" and you will find some .log file (etc: 2014-7-6.log) ,please open these log and copy text and sent to me ,thanks :)
Tony
PostPosted: July 7th, 2014, 2:50 am
Crash log occurs only when changing icons, but not always.
I wrote about it here:
viewtopic.php?f=3&t=4683
That's what we're talking, there is no crash log. This is a problem with the display and operation.
Take a look:
VERSION 1.0.4 (4 examples of widgets)
As you can see, there is no display, or displays only the background and the widget does not work.
AND NOW.....
Take a look:
VERSION 1.0.3 (4 examples of widgets)
The last of the widget is the one you were talking about, that is too big or I have too little RAM.
This is the source of widgets:
http://slavoo123.deviantart.com/art/Lg- ... -464386520
http://jimking.deviantart.com/art/LG-G3 ... -459976087
http://jimking.deviantart.com/art/MIUI- ... -459486328
http://slavoo123.deviantart.com/art/And ... -464915265
And what do you think?
As you can see, to version 1.0.3 everything works perfectly. On 1.0.4 does not work at all.
I can not explain to you more simply, I gave screens, I wrote everything.
I recall again the error of the non-functional autolocation. No finds nothing.
That's all from me.
Slavoo
PostPosted: July 7th, 2014, 8:09 am
Hi Slavoo,
I had try to fix this problem, please help me to test ,thanks :)
Tony
Slavoo
PostPosted: July 7th, 2014, 8:59 am
Tony almost works. Look at the sceens.
Is cut down widget:
VERSION 1.0.4 (Size [4x3] and [4x4])
VERSION 1.0.3 (Size [4x4]) - Size 4x3 you know how to screen, did not give
And still other two problems:
- Do not operate autolocation
- Crash when changing icons
LOG:
2014-07-07-19-05-50.rar [996 Bytes]
Downloaded 24219 times
Why in the previous version did not have this problem with the display? It can copy the code from the old version to the new, and will be the problem. :)
Waiting for fix :D
PostPosted: July 7th, 2014, 10:59 pm
I had try to fixed the "cut down" bug,please re-download and test ,thanks :)
download: http://android.xwidget.com/download2.php
Is cut down widget:
Waiting for fix :D
PostPosted: July 7th, 2014, 11:11 pm
Now works properly! :D
Bravo Tony..!
about geolocation bug wait a reply from Slavoo. I'll try to test it too even I never use it..
Edit: Seems that automatic search of the location doesn't show up anything..
PostPosted: July 7th, 2014, 11:32 pm
WORKING! :D :D :D
The remaining two errors:
- Autolocation (Tony look at the Private Message)
- This bug: viewtopic.php?f=3&t=4683
PostPosted: July 7th, 2014, 11:42 pm
From what I see, a manual search using the database AccuWeather, but not quite.
For example:
http://www.accuweather.com/pl/pl/wola-m ... st/1383724
This does not search, but searches for example:
http://www.accuweather.com/pl/pl/zlotok ... ast/274657
It is also a small village.
Conclusion. XWidget does not search all the small location.
Top this problem is solved in Fancy Widget. There, everything works excellent in terms of location and association with Accuweather.
You can check it out.
PostPosted: July 8th, 2014, 7:43 am
Is not fully true..
Using the manual search I can find my location (with 70.000 people). Trying with geolocation I receive no results or a city 30km away.
So I think that there is a generic problem, not only with the small cities..
PostPosted: July 8th, 2014, 7:45 am
There appears nothing, or shows as before that is a big city.
PostPosted: July 8th, 2014, 7:47 am
jimking wrote:
Is not fully true..
I wrote to Tony for PM, so took advantage of the search engine Accuweather. As I wrote, it is perfectly solved in Fancy Widget.
PostPosted: July 10th, 2014, 3:47 pm
1.04 installed. same as 1.03 - fix the location issue and it's a daily driver. some of the best looking widgets I've seen
PostPosted: July 11th, 2014, 12:45 pm
Dev is working to repair errors. Wait for the next version.
PostPosted: July 15th, 2014, 8:08 pm
Still having trouble with downloading weather on my phone.
- The PC is OK.
- AccuWeather application OK
- Fancy Widget OK
- Xwidget - no working: (
Now I at 06:04 on the night, although the window beautiful sunshine. Last updated from the server 22:35 but writes "Weather has been updated"!
Conclusion:
We continue to improve the following errors:
- Autolocation
- Downloading weather
EDIT:
viewtopic.php?f=3&t=4670&p=9123#p9123
PostPosted: July 16th, 2014, 3:18 pm
Any news on the location fix?
PostPosted: July 16th, 2014, 10:36 pm
At the moment we have no information from the dev.
We are waiting patiently for the update.
PostPosted: July 19th, 2014, 3:03 am
Tony. Looking forward to the update. Write something on this topic, please.
Thanks!
PostPosted: July 19th, 2014, 3:24 am
Thanks!
Tony is out for this month. I received a pm from him and is traveling..
Don't forget that is summer.. ;)
PostPosted: July 19th, 2014, 3:35 am
Thanks.
PostPosted: July 27th, 2014, 4:52 am
Hi. I want to link an app to a custom hotspot in widget. How am i supposed to do that? Any help? I found out how to add hotspot in the android editor and how to select my preferred area.Then i found click event.It says open but what i should write in order to open an app?My thought is to open clock app when i press clock in widget,diary when i press date in widget and a weather app when i press weather in widget.Any help please?Thank you and sorry for my English.
PostPosted: July 27th, 2014, 5:18 am
when you add your widget to screen and tap it for the first time, XWidget will ask you to choose the app you want to open.
PostPosted: July 27th, 2014, 5:40 am
You set up a hotspot, you have to add also the core - shortcut
The core shortcut add option !Open
See this widget:
http://slavoo123.deviantart.com/art/And ... -469165876
PostPosted: July 27th, 2014, 6:13 am
See this widget:
I do that. But what i have to write after that in order when i click it to open an app?
PostPosted: July 27th, 2014, 6:16 am
doublepost. sorry...
PostPosted: July 27th, 2014, 6:29 am
In Android:
In PC - I don't know. I have not used this option on PC
You may need to select an exe file
PostPosted: August 5th, 2014, 7:32 am
I see that Tony showed up, so I hope to progress in work,
PostPosted: August 5th, 2014, 11:10 pm
After repairing autolocation propose to add more:
- Cleaning of the last places in the whole or a single choice
Option to enable or disable the refresh autolocation widget
Sometimes we are in one place for a long time so you do not need to refresh every weather also refresh the location
When we travel we turn automatically update weather and location.
Thanks!
PostPosted: August 14th, 2014, 5:00 pm
for autolocation, you need to add GPS permission I believe.
The widget would need to have GPS permission to be able to use phone's GPS.
PostPosted: August 14th, 2014, 5:07 pm
Discovered America? ;)
At the moment does not work autolocation.
PostPosted: August 15th, 2014, 7:11 am
The issue is known Slavoo. No need to post the same things again and again..
When Tony will be ready he will let us know!
PostPosted: August 19th, 2014, 2:50 am
Please check the new beta 1.05 version and report..
Thank you
PostPosted: August 19th, 2014, 3:41 am
When you try to install I get the message:
An error occurred during the analysis package.
PostPosted: August 19th, 2014, 3:48 am
Probably a corrupted file, because there is not even an icon Xwidget
PostPosted: August 19th, 2014, 4:01 am
Hi Slavoo, What Android version of your phone?
PostPosted: August 19th, 2014, 4:03 am
Hi Tony.
Android 2.3.6 - Samsung Galaxy S Plus
ROM I9001BVKPC - GINGERBREAD.BVKPC
Core: 2.6.35.7-perf root@DELL155#1
PostPosted: August 19th, 2014, 4:09 am
Download again Slavoo! I downloaded the .apk file and works ok..
Corrupted download..
PostPosted: August 19th, 2014, 4:13 am
Slavoo wrote:
Hi Tony.
Hi Slavoo,
Sorry that no longer support below Android4.0 version.
Tony
PostPosted: August 19th, 2014, 4:15 am
Super! Thanks!
I have no words. :((((((((((((
PostPosted: August 19th, 2014, 4:22 am
If this is the case have it back to Fancy Widget. He works on 2.3.6 and there everything works, including autolocation.
Bye!
PostPosted: August 19th, 2014, 4:40 am
Tony
This can't be changed..? Personally I have 4.0+ and yes I know that OSs like Slavoo's 2.3.6 are too old, but as you see there are still people with old phones..
@Slavoo: We speak about two different cases! You can't compare Fancy Widgets with XW! FWs has only weather/digital clock widgets. Instead of XW is a pc program port on Android with cores,tags. And in the future updates will support even calendar,photo album etc. So there is no sense to compare..
And in the other hand, hey man..... Android 2.3.6 is tooooo old nowdays!!! :!: :o
I have my first Android phone SGS and I upgrated to 4.4.2 Cyanogenmod and works more than fine!
This rom uses even less ram than the old 2.3.6! Also you lost the 80% of the Android apps!
Just UPGRADE!!
PostPosted: August 19th, 2014, 5:13 am
I do not believe that you can not fix autolocation on 2.3.6! If you could do it in a Fancy Widget that works on 2.3.6 you can do here.
Tony did the dumbest thing you can do. He took the best widget hundreds of thousands of users with older phones in the world !!!
Just UPGRADE!!
I can not do that. I do not want to spoil the phone. I know nothing about this, nor did I know anyone who would do it for me. I have to stay at 2.3.6 until you buy a new phone. And do not buy at the moment because I have no money. Maybe next year for two years.
I'm not rich.
PostPosted: August 19th, 2014, 5:16 am
The only sensible solution is what I see:
- Repair autolocation version 1.0.4 and release a version for Google Play.
- Making a brand new Xwidget 2.0.0 for Android 4.0 + and also adding to Google Play.
It will satisfy all.
PostPosted: August 19th, 2014, 5:22 am
Hi Slavoo,
I am very sorry, this is just a beta version,I think I do not have to consider comprehensive, I will reconsider to change back to support android 2.3 and fix autolocation, thanks Slavoo for your advice.
Tony
Just UPGRADE!!
I'm not rich.
PostPosted: August 19th, 2014, 5:54 am
Repair autolocation for 2.3.6 and will be OK.
Let it works as it should. And this moment is one of the lacunae.
Just finish what you started and just do the next thing. That's my opinion.
PostPosted: August 19th, 2014, 6:21 am
Hi Slavoo,
Thanks,You are right.
Lets talk about the Autolocation.
Do you means that the v1.04 can not get the correct location by manual search ?
Or Do you means that you need the XW weather auto get B location weather info when you travel from A city change to B city ?
Tony
PostPosted: August 19th, 2014, 6:25 am
Slavoo:I can not do that. I do not want to spoil the phone. I know nothing about this, nor did I know anyone who would do it for me. I have to stay at 2.3.6 until you buy a new phone. And do not buy at the moment because I have no money. Maybe next year for two years.
I'm not rich.
It's easy and you will don't spoil your phone! The phone is old and you have no guarantee anyway. Make a good backup and with three steps you will have a new phone. And if anything goes wrong, with the hard reset you will have the same rom as before.
When I bought my first android on 2010, I didn't know a damm. Then searching on blogs and forums you can find and learn anything!
Don't be afraid!! Also there are a LOT of videos/tutorial on YouTube..
You will have your old Samsung Galaxy S Plus with Android 4.4.2 KitKat! ;)
PostPosted: August 19th, 2014, 6:59 am
Tony:
Manual search function. You have to enter the name of the town or district in the city and is downloading info from AccuWeather!
It does not work autolocation different locations. I do not want every time when I change the location manually re-look. I want the widget itself found my location.
PostPosted: August 19th, 2014, 7:03 am
@jimking
I was looking for. I do not know which rom possibly would upload. Everyone says that consumes a lot of battery.
Besides, I do not know how to install. You have twrw, gapps and others. I know nothing about this, and how on something I do not know that I do not.
PostPosted: August 19th, 2014, 7:08 am
Slavoo wrote:
Tony:
What will happen when you click the Right-Top button in ChangeLocation Activity ?
PostPosted: August 19th, 2014, 7:11 am
@Tony:
Nothing. Search nothing. Or search big city no district.
I want nothing more. Just to the widget itself looking for location and gave me the weather! :) That's all.
PostPosted: August 19th, 2014, 7:14 am
I live in Poland, in Warsaw. When I press the button autolocation shows Warsaw. But when I type in the search neighborhood that it finds, as well as searches for smaller cities. Autolocation does not.
Do you understand what I write?
PostPosted: August 19th, 2014, 7:20 am
Slavoo wrote:
@jimking
On my SGS I have installed the C11 cyanogenmod and all parts works properly, and NO BATTERY issues! Where you read that "Everyone says that consumes a lot of battery.."
You only need the "ES Explorer" app to make a backup of all your apps, then check if your phone has unlocked the 3-buttons download/recovery mode, you download the zip file with the rom, put it into your phone with usb, and with a simple process that you can find everywhere on youtube or XDA, put your phone in download mode and the rom will be installed..
Anyway....
Continue your discussion with Tony, about the GPS/location that's more important..!
I hope Tony can help you find the solution..
PostPosted: August 19th, 2014, 7:26 am
@Tony
Look at this:
This is locations from Accuweather:
WARSAW:
AND SMALL CITY outside Warsaw:
Xwidget does not search for anything or show a big city. In my case, Warsaw. It does not matter whether or not GPS enabled.
Small town does not show at all.
As I wrote, it works just manually typing the name.
Ufff...
@jimking -
I do not know which rom good. I need a link and a link to the tutorial
Can I install, but a lot of work and I have not done and I'm scared.
Maybe someday ....
For now, I have 2.3.6 and I want to XW work properly.
Thanks for the suggestions jimking.
PostPosted: August 19th, 2014, 7:33 am
Maybe someday ....
Ok.. If you change opinion tell me. It's worth it..
PostPosted: August 19th, 2014, 7:35 am
I'm at the computer all the time today now and all the time I opened this forum so willing to help Tony resolve problem. I will be testing etc
But that's not the point, if I change my mind or not.
The idea is to just work on 2.3.6
After all, not only did I have this problem but many other people around the world!
PostPosted: August 19th, 2014, 7:44 am
One more thing Tony. Do not use GPS !!!
Accuweather uses the location of a mobile phone base station.
PostPosted: August 19th, 2014, 8:52 am
Thanks!
It would be good if these options were added, but may be permanently refreshing location and weather.
Tony I hope that solve the problem for 2.3.6
I look forward to your reply.
PostPosted: August 19th, 2014, 8:57 am
Thanks, this is a great idea, I will check it :)
Thanks!
Yes, I had this plan , it will for 2.3
I will create some single demo to sent to you,please help me to test :)
PostPosted: August 19th, 2014, 9:06 am
No problem mate. Please link to download when ready.
PostPosted: August 20th, 2014, 6:56 pm
Hi Slavoo,
I had re-upload XWidget for Android v1.05 ,support Android v2.3
1. try to fix the autoLocation function
2. add "AutoRefreshWeather when network change and connected"
3. add Text Control property "Trimming Style"
PostPosted: August 20th, 2014, 8:58 pm
Hi Tony.
Autolocation unchanged. It does not work. :(
PostPosted: August 20th, 2014, 10:17 pm
@Tony
I do not know how it is solved for example in Fancy Widget or Accuweather but according to the test that you gave me, almost every time shows a slightly different coordinates, but strictly within the same location or within a radius of several tens of meters, it is the difference up to 100 meters according to my assessment looking at a Google map.
Can see what data can be assigned, for example, to place "Mariensztat (Masovia Poland)" or another as shown in the pictures in my post above with pictures of Accuweather. I do not know if this is certainly coordinates, but I think so, because the test works great!
PostPosted: August 21st, 2014, 1:51 am
Bugs for the latest version: :!:
1)
Doesn't work....
2) The "Edit" screen doesn't open at all.. Black screen and returns to the homescreen..
Tested on SGS2 4.0.3
PostPosted: August 21st, 2014, 3:54 am
What is "Trimming Style" ? How use this?
PostPosted: August 21st, 2014, 4:34 am
Open the designer, add a text component and write any text (fill all the space).
Open the sub-menu "Format" and test the various options of the "trimming style" to see what happens..
PostPosted: August 21st, 2014, 4:57 am
Slavoo wrote:
Hi Tony.
How do you test?
Please test as this:
1. Uninstall XWidget
2. Install last version of XWidget's apk
3. Make sure you had checked the Option of Phone SystemSetting-->Location-->Use wireless networks
4. add a Weather widget onto your desktop/launcher,then it will autolocation after 1-5 seconds.
5. Or open ChangeLocation activity and click top-right button to start location.
PostPosted: August 21st, 2014, 5:17 am
How do you test?
3. add a Weather widget onto your desktop/launcher,then it will autolocation after 1-5 seconds.
4. Or open ChangeLocation activity and click top-right button to start location.
DONE ALL!
RESULTS:
1. After installing and add widget
2. Menu Change Location
3. Menu Change Location after click in RIGHT-TOP button:
NOT WORKING! I've tried 30 times and nothing :(
PostPosted: August 21st, 2014, 5:27 am
After pressing the HOTSPOT (Update weather) the weather updates, location = GuangZhou
Maybe even let the other person check. For me does not work as I showed on the pictures.
PostPosted: August 21st, 2014, 5:32 am
Slavoo wrote:
How do you test?
DONE ALL!
RESULTS:
Hi Slavoo,
Thank you very much, I understand and I found where is the problem, I really fixed it this time ,please re-download the apk and install to test 8-)
Hi Jimking,
the "Triming Style" property of TextControl had fixed,please re-download and test.
PostPosted: August 21st, 2014, 5:42 am
WORKING !!!
Thanks Tony !!!
Tomorrow I travel, so check closely and write here.
PostPosted: August 21st, 2014, 5:43 am
For You TONY:
:D
PostPosted: August 21st, 2014, 5:52 am
According to me you can add to market Google Play
PostPosted: August 21st, 2014, 6:22 am
Is not ok yet Slavoo...
Hi Jimking,
Tony, I tested. The txt trimming style applies correctly, but now on the background appears a "black" image..
Look:
THE AUTOLOCATION WORKS ALSO FOR ME! :D
PostPosted: August 21st, 2014, 6:52 am
This is very strange, whether the black image is the other controls?
Or Can you make a simple demo widget with one Text control and timming style to test?
PostPosted: August 21st, 2014, 7:31 am
This is a full functional widget. I tested adding a custom txt with trimming enable, and after I updated the widget on my phone, this "image" appeared. Like the transparent space of the designer filled with black.android.xwidget.com/page/widgets/weather/2014/0714/Next_Weather_Mod.html
PostPosted: August 21st, 2014, 7:41 am
jimking wrote:
This is a full functional widget. I tested adding a custom txt with trimming enable, and after I updated the widget on my phone, this "image" appeared. Like the transparent space of the designer filled with black...
Can you upload this widget to test?
PostPosted: August 21st, 2014, 9:50 am
This is the widget Tony:
http://android.xwidget.com/page/widgets ... r_Mod.html
I use it with all the prev versions but only with the latest version I have this issue with the background image, after the trimming style was activated..
PostPosted: August 21st, 2014, 5:42 pm
Hi Jimking,
I download this widget and sent to my phone ,I can not found the issue with the background image after the trimming style was activated.
I test on Meizu M9(Android 2.3) and Nexus5 (Android4.4.4)
Let me do some more tests..
Edit:
I made the same procedure and now works Tony! No issue.. STRANGE! :|
Ok, then.. If you're ready update officially the app.
Thanks for your hard work! :)
PostPosted: August 21st, 2014, 7:11 pm
On Android no hotspot button for update weather
and small place to city.
