PostPosted: June 27th, 2013, 12:57 pm
How is it possible to set the icons to be at the bottom instead of at the top of the screen ?
I very much like the idea, look and feel of this software but I'll not be using it with all the icons at the top.
Thank you,
Etienne
PostPosted: October 12th, 2013, 1:09 pm
try to add fake transparent icons
PostPosted: March 18th, 2014, 3:48 am
disable Auto arrange icons under view (right click menu) and move them to the buttom
