PostPosted: June 14th, 2013, 7:25 am
What arguments for application and folder shortcuts i can use so they can open in maximized windows?
PostPosted: June 16th, 2013, 2:54 am
Do you provide any support for your application ??
PostPosted: October 12th, 2013, 1:13 pm
AppData\Shortcuts\Links set in properties maximized for your app
PostPosted: October 12th, 2013, 1:43 pm
check also this tutorial: http://howto.cnet.com/8301-11310_39-200 ... n-windows/
PostPosted: October 12th, 2013, 2:10 pm
if you have many shortcuts and want to edit them at once, check the comment from Rocky:
http://stackoverflow.com/questions/4169 ... and-prompt
