 Post subject: XLaunchpad not working
PostPosted: April 17th, 2013, 10:53 pm
hai i really like "XLaunchpad" and find it far more usefull than XWidget,however i see that XLaunchpad,is not being actively developed.please continue developing as the one other alternative is WinLaunch,there arnt much alternatives.
XLaunchpad is not working =
1)when i click computer or document,nothing happens,i can only see the animation,but it dosnt get executed--i use win 8 64bit
2)i cant drag shorcuts to XLaunchpad,in drag and drop mode,again when i drag and drop,nothing happens
--please fix these problems and update the program ,and if you dont like to develop,make it open source,so the development can continue,all the application launchers are becoming outdated,i use a launcher called 7stacks and wish to migerate to something else,i found this good enough,so please continue with your development,thank you.
PostPosted: April 18th, 2013, 12:39 am
Hi sanji765,
Thanks, I am still developing with XLaunchpad. I will release a new version about at next week.
I am uses win8 64bit too, but I have not this problem ,I tested click Computer/Document and works fine. Please make sure your XLaunchpad is last version and download from xwidget.com .
Or you can try XLaunchpas's portable version. download from here : http://xwidget.com/download_xlp2.php
just unzip it and run XLaunchpad.exe
PostPosted: April 23rd, 2013, 6:01 am
Thanks mate ;)
