 Post subject: How to create a folder
PostPosted: August 10th, 2012, 4:52 am
I can't find how to create a folder with subitems. The Add->Folder just creates a link to a folder.
(I've manually edited the "items.xml" file but I think there must be a function in the GUI)
Regards, Tom
PostPosted: August 10th, 2012, 4:54 am
Simply drag one icon over another to create a folder.
PostPosted: August 14th, 2012, 10:17 pm
It works. Great. Thank you.
PostPosted: October 24th, 2012, 4:04 am
I have found that some applications will not combine into a folder when I drag the icon over top of another icon. For example, I have 2 icons in Launchpad - VideoReDo and Freemake Video. When I try to drag one over top of the other, the icon just reverts back to where it was originally on the screen. This does not happen to all of my icons, only some of them. Is there some kind of requirement needed in order to combine these applications into a single folder? I have a number of different video applications that I want to combine into a single folder to reduce the clutter on Launchpad.
Thanks,
Joyce
PostPosted: October 12th, 2013, 12:50 pm
I sometimes can't create folders in the windowed mode. But I can always create them in items.xml file manually.
