PostPosted: June 12th, 2012, 12:22 am
I've this problem with Xlaunchpad under win 7 X64 :
Every time I click on a app icon in XlaunchPad this icon is duplicated and nothing start... and these icons are still there even after restarting the system ...
However it's work well with system shortcuts like control panel.
I've tried severals tricks like running XlaunchPad in admin mode, turning off firewall and antivirus etc. but nothing worked.
thanks if you could help.
Yann.
PostPosted: June 12th, 2012, 8:36 am
coryan wrote:
Yann.
Hi Yann,
thanks for your feedback, I uses XLP under win7 32bit, I test and no this problem.
Can you help me to find more information about this problem? thanks
Tony
PostPosted: June 12th, 2012, 10:57 pm
Hi Tony,
If I can help, it would be with pleasure, tell me what you want to know.
Yann.
