 Post subject: Dock question
PostPosted: November 5th, 2019, 4:18 am
Hello everyone:
I am creating a dock with completely white icons. I would like the icons to change color by hovering over them.
I have managed to do this by creating several groups of icons with different colors and changing the icon by placing the mouse above them, but I would like to know if it is possible to create a script to be able to choose any color.
Thank you very much, and forgive my English :)
 Post subject: Re: Dock question
PostPosted: November 5th, 2019, 12:30 pm
Hi! I created many dock widgets. Since you use png images the only way to change their colors is to reproduce the "colourization" values of the designer though the java script. Currently I don't have my laptop and I'm replying to you through my phone. Personally I'm not sure about the form of the js code . So or wait for a reply from another member or attach the .xwp to check your widget asap, to see if I can find another "trick" for this...
Users browsing this forum: Google [Bot] and 95 guests
