PostPosted: October 25th, 2019, 7:15 am
Hi widget team,
On the review page of Xwidget on Steam i saw very cool widgets ( page 21/40 and page 37/40 of review page), i can't find them with the "find more widgets" in Xwidget app. Could you please help me to find them, please see my attachment for more details? Thanks.
ss_f30dcd7935085d46bdd43e1fc73dd6ce8a08dc7c.1920x1080.jpg [ 517.14 KiB | Viewed 22579 times ]
ss_8b81d83912b3324c85f3e5b1247699cf309f9865.1920x1080.jpg [ 724.99 KiB | Viewed 22579 times ]
PostPosted: October 25th, 2019, 10:12 am
Hello shinobitiger,
The first one is "Angle Futuristic Widget HD" and the second is "Tron Docks"
You can find them through the built-in online gallery search field or through my gallery on DeviantArt
https://www.deviantart.com/jimking/gallery/
PostPosted: October 25th, 2019, 4:53 pm
Hi Jimking, thanks for your help! i found these 2 widgets on your gallery on Deviantart, just notice that i can not find them on built-in online gallery (through "More Widgets..." button if that is what you mean).
P/S: i installed almost your widgets for Tron, they are really cool. Thanks for your hard work.
One more thing: i downloaded your widget called "Desktop Dance" and made an optimization for the Java Script code (reduced from over 1000 lines of code to about 137 lines of code) if you need that to modify the widget i will send it to you, just let me know.
PostPosted: October 26th, 2019, 1:08 am
The built-in gallery has a search field on top.
I have forgot to upload them there!? My bad. :roll:
Thank you for optimizing the code but doesn't matter. If I remember well are just gifs with the simple hide/show save ini function.
If you want you can send me the code just to check the other way. I know that with js there are more than one ways to do the same thing :)
Users browsing this forum: No registered users and 85 guests
