 Post subject: Little question
PostPosted: September 23rd, 2019, 1:01 pm
Hello,
Is it possible to ensure that this list is arranged in alphabetical order and menus are not open?
https://gyazo.com/d1e959ec44cb961edcfd14ca71151178
thx :)
// ===== Contact ===== //
https://discord.gg/9vyhv3F
// ===== My Widget ===== //
 Post subject: Re: Little question
PostPosted: September 24th, 2019, 12:50 am
Hi Rom,
The only two ways to do it is
1. Through the "Manage Widgets" tab
2. Pressing right click on empty space at the installed widgets tab
The aphabetical order works fine for the main names. (I don't actually know what are these sub-menus showing at your screenshot. I never have them!)
PostPosted: September 24th, 2019, 7:22 am
I think this won't work for me look
https://gyazo.com/619f12ea5f7b6e283c98ce4ed148405d
I try to create suite of widget for a full theme :)
PostPosted: September 24th, 2019, 8:45 am
I see. But I never had/used these sub menus there.
The alphabetical order works fine but as I said only for the first main names of the widgets, not for the sub names.
But why not do it with the 'normal way'?
Create separate widgets, and when you want to create a suite, put them all on the desktop and save the whole process as Theme. And upload that theme file.
When the users will run it, they will have all the widgets in place-all in one suite! ;)
PostPosted: September 27th, 2019, 1:28 am
Yes I see, I will not have too much choice anyway :)
But for a future update it may be cool to be able to manage subfolders for our theme suite of widgets
