 Post subject: Drag and drop to folder
PostPosted: August 26th, 2019, 8:49 am
Hello.
I am just trying to make a drag and drop widget which would work exactly the same as recycle bin one but I just want the files to go to specific folder, specified by me rather than to the recycle bin.
I am guessing it is possible, I just do not know how to do it.
Any help will be much appreciated!
I tried to google but the results are completely unrelated.
PostPosted: August 26th, 2019, 1:40 pm
1. Create a new widget
2. Select the DragDrop object
3. Add a Foldercore.
4. Select one of the text boxes and use the foldercore as its binding object.
5. Under Others in the Attributes section, make sure Accept DragDrop is checked.
6. Click on the foldercore in the area below the design area.
7. choose the folder you want to send stuff to under folder path.
Just drag and drop files over the widget and they move to the folder you selected!
PostPosted: August 26th, 2019, 2:12 pm
It works perfectly! Thanks!
I dunno what I did wrong because I remember checking all those things and setting up the path. Probably I changed too much, including things that should not be changed. Anyways, thank you once again bro.
PostPosted: August 26th, 2019, 3:39 pm
You're welcome! :D
PostPosted: September 7th, 2019, 3:40 am
The drag drop option can be also used for the shortcuts and recycle bin widgets.
