PostPosted: August 20th, 2019, 3:17 pm
Hi, As the subject says, I want to run a loop in the WidgetOnLoad function to change text colors, adding a numerical
variable to the text name. (IE: "text" + i + ".font.fill.color = TextColor1"), where 1 is added to i at the end of each loop.
I can do the code for the loop but when appending the variable it doesn't change the text colors. Is there a way to do this?
What command(s) do I need to make it work? Code I have tried is below.
The text components are named": text1, text2 etc. up to text15.
//   Color Variables
var TextColor1 = rgba(0,130,230,255);
var BorderColor = rgba(0,60,100,255);
var BackColor = rgba(0,0,0,127);
var LineColor = rgba(0,44,80,255);
function widgetOnLoad()
i=1
     while(i <=15)
     "text" + i + ".font.fill.color = TextColor1";
     i++;
I also tried:
eval("text" + i + ".font.fill.color = TextColor1");
and:
do{
I can see that I get the correct strings from the code loop but it doesn't change the text colors?
I have a text launcher with 75 different text components and I'd rather not have to add them all one by one if I don't have to.
If not, is there a way to have different widgets use the same variables?
