PostPosted: December 19th, 2018, 3:44 am
Text should say good morning, good evening, good afternoon
but how? :D
that's what i found out
if (curHr < 12) {
console.log('good morning')
} else if (curHr < 18) {
console.log('good afternoon')
} else {
console.log('good evening')
how can I integrate this here and relode it every hour
function widgetOnLoad()
text1.text =
Thank for Help
PS. is there any Documentation for the funktions
example
text1.text = ?
Thanks Again ;)
PostPosted: December 20th, 2018, 1:02 am
Hi!
You can use two ways:
1 way = java script
Took it as example from here:
https://www.deviantart.com/jimking/art/ ... -365686066
create 3 texts:
text1 = good morning
text2 = good evening
text3 = good afternoon
and add this js as base (this is for two components)
function datetimecore1OnUpdate(Sender)
    var mydate = new Date();
    var h = mydate.getHours();
    if(h>19||h<6) //night
       text1.visible = true;
       text2.visible = false:
    else          //day  6:00~20:00
       text1.visible = false;
       text2.visible = true;
or modifying this kind of js:
https://www.deviantart.com/jimking/art/ ... -370894930
or create 3 pngs with these words and add 24 images in a folder, and rename the corrisponding image to an hour 1,2,3,4....23
so create "good morning" image with name 7,8,9,10,11,12,13,14,15 etc
PostPosted: December 21st, 2018, 1:54 am
Thank for you anwser i will try it ;)
PostPosted: January 2nd, 2019, 4:33 am
i used this, and it looks like it works
var curHr = mydate.getHours();
if(curHr<12) //morning
morning.visible = true;
evening.visible = false;
afternoon.visible = false;
hello.visible = false;
else if(curHr<16) //Hallo
morning.visible = false;
hello.visible = true;
else if(curHr<18) //evening
evening.visible = true;
else //afternoon
afternoon.visible = true;
any objections or suggestions for improvement.
Thanks
