PostPosted: October 21st, 2018, 8:28 pm
I would like to add to the "Cyan Clock Weather Widget" (attached) the following functions:
1.) Show next upcoming Alarm (Alarm Clock)
2.) Show Profile from Volume Butler or System Ring/Vibrate Profile
3.) Show unread Messages from Textra or System SMS App
4.) Show missed Calls
5.) Show Calendar Events
6.) Show Info from GSam Battery Monitor a.) Amount Used b.) Time Remaining c.) Show Temperature and Voltage
I tried myself but can't get very far, see screenshots.
Only battery Percentage is working on the phone, Remaining Time and Volumes not.
Can somebody please help?
Can we overcome the new restrictions in Oreo and Pie?
I am currently using " Chronos Widget" and they are inactive and will discontinue the extensions soon.
Thanks
Robert
File comment: File contains the widget
Cyan Clock Weather 7 with Extensions.rar [3.43 MiB]
Downloaded 748 times
File comment: Droid View
File comment: View on PC
PostPosted: October 22nd, 2018, 5:44 am
ChinghissKhan the functions you want to add are not currently supported. We will add them in the next future versions. Tony, the dev, will check your topic and we will add all this to our to do list.
Thank you
PostPosted: October 22nd, 2018, 12:19 pm
Thank you
Thank you
Users browsing this forum: No registered users and 104 guests
