PostPosted: October 5th, 2018, 5:04 am
Hello !
I have a problem with the "Aero Blur" effect that does not display correctly.
I forced the effect "Aero Blur" in windows but the display with XWidget does not work ....
Here is a screen. Thank you ;)
No Arero Blur effect,
can you be an idea why it does not work, may be a bad configuration of my pc ....
Thank you :)
// ===== Contact ===== //
https://discord.gg/9vyhv3F
// ===== My Widget ===== //
PostPosted: October 5th, 2018, 7:55 am
The real aero blur effect has been removed after win7.
About win 10 though be sure to have activated
https://www.askvg.com/how-to-enable-aer ... indows-10/
https://www.tenforums.com/customization ... -aero.html
Personally I don't use that option any more to avoid bad visuals as yours..
PostPosted: October 5th, 2018, 12:36 pm
Ok I see, I just look at the links that you made me but it does not change anything, it's not very serious ...
By cons I had other questions, is it possible to open another Widget from mine? If so, what is the command line to use?
Thank you :)
PostPosted: October 5th, 2018, 1:14 pm
No, there is no way to interact between widgets.
It will be cool yes, but it's not possible..
PostPosted: October 5th, 2018, 1:27 pm
Ok thanks for your reply :)
Users browsing this forum: No registered users and 130 guests
