PostPosted: September 25th, 2018, 9:54 am
I am looking for a simple GPU Temperature Monitor. The only one I can find was the "Steam Punk" one and while it looks nice I really just want something that's simple and none intrusive. I just want to monitor the temperature and for some reason I can't find a widget that works with XWidget. (most google search results tell me to download other programs. I don't want to download another program, I just want a widget that'll work with what I've already got installed) Can someone please point me to a widget like this please?
Also, is there ever going to be a search feature for the XWidget gallery? It's super annoying going there and not being able to search the widgets.
PostPosted: September 26th, 2018, 2:40 am
XWidget as the rest widget engines need external programs to read the necessary info.
Read these topics please
viewtopic.php?f=7&t=2047
viewtopic.php?f=8&t=6589
viewtopic.php?f=8&t=3281
For a more "professional" reply please wait the dev Tony. He's out home these days but I have already sent your topic and he will reply asap.
XWidget's built-in online gallery has a search field @myst13121. Right click on the XW's icon tray and use the "More Widgets..." option.
(please download and install the latest version from the main page http://xwidget.com/)
The search field is placed on the top right
PostPosted: September 28th, 2018, 9:34 am
I ended up downloading MSI Afterburner and that displays the info I need.
As far as the search goes, I meant on the site and not in the application, because when you go to https://www.xwidget.com/xwidget/plus/list.php?tid=1 there is no search. (at least none that I can see, maybe I'm overlooking it) I guess I could use the search in the application itself, but I would much rather use my own browser instead of being forced to use their interface.
But thanks for the info anyway :)
PostPosted: September 28th, 2018, 10:22 pm
You're welcome. We will try to optimize the webpage gallery and add a search field there too.
