 Post subject: Add days
PostPosted: September 2nd, 2018, 10:10 pm
Hi!
I'm new at this, but I want to create a widget which can show the date in 3 days, in one week and in 3 weeks.
Like "In tree days it's 2018-09-06" etc.
Any suggestions?
 Post subject: Re: Add days
PostPosted: September 3rd, 2018, 12:02 am
The date time core shows the current data.
You need to use the accuweather core.
I have made a lot of forecast widgets that show the forecast /date for the next days.
If you need more help please tell me and I will write you here the tags that you need to use..
PostPosted: September 12th, 2018, 10:05 pm
Thank you. That's a good start.
I want to do something like this:
In 3 days: dd/mm
In one week: dd/mm
In tow weeks: dd/mm
In tree weeks: dd/mm.
PostPosted: September 13th, 2018, 3:47 am
As I said you need to use the accuweathercore for this (that supports up to 15 days data)
The ${......}1 tags are for today, ${......}2 for tomorrow.. etc
So for example for your "In 3 days: dd/mm" you have all these tags to choose from depending of what you want
https://imgur.com/a/zBWf5Bt
For the dd/mm use this tags:
${dayNumb03}/${month3}
PM: Maybe there is a way through java script code to visualise more dates but I don't know the form.
But 15 days are enough I think..
