 Post subject: Display +/- hour with jv
PostPosted: July 12th, 2017, 7:39 am
I have 3 txts and I would like to visualize the current hour (middle txt), hour -1 for the left txt and hour +1 for the right one.
Something like this screenshot, where the 10 is the current hour, the left is hour-1=9 and the right hour+1=11
How can I reproduce it with java script...?
I attach a simple demo widget
testhours.xwp [5.97 KiB]
Downloaded 1197 times
PostPosted: July 12th, 2017, 10:27 am
var hr;
// function to update the time
function updateTime() {
//initialise the time function
var time = new Date();
//returns the date/time in a string format
hr = time.getHours();
hr = hr + 1;
in main.xul
<cores>
<dateTimeCore name="clockTimer" onUpdate="updateTime"/>
</cores>
yereverluvinuncleber, I added your script but I need to assign the texts.. :?
PostPosted: July 12th, 2017, 10:48 am
There you go Jim.
testhours.xwp [6.28 KiB]
Downloaded 1181 times
PostPosted: July 12th, 2017, 12:14 pm
Thanks Dean..! Let me try it :)
PostPosted: July 12th, 2017, 12:54 pm
You'll have to add the minus side yourself but it'll be easy enough to do so. You have a serious need for some javascript skills. As I suggested in my DA note to you, I'm willing to give you a little tuition.
PostPosted: July 12th, 2017, 3:01 pm
Thanks again Dean. Check my reply on DA..
PostPosted: July 19th, 2017, 7:44 am
How did you get on Jim?
PostPosted: July 19th, 2017, 1:30 pm
All ok Dean! Thanks again for your help.
I used your script here:
http://jimking.deviantart.com/art/Son-O ... -692249411
Users browsing this forum: No registered users and 85 guests
