 Post subject: Countdown Timer
PostPosted: June 24th, 2017, 8:33 am
Hi i wants to make a timer where i can type 3.00.0 and it wil go dow to zero and go back to 2.59.59
and a start and stop buttom can anybody help
/Stonie
 Post subject: Re: Countdown Timer
PostPosted: June 24th, 2017, 11:24 am
Stonie if I remember well there is a timer widget posted on DA. I don't know if you can find any similar one in the official gallery. I will search and if I find something I will post the link here
PostPosted: June 25th, 2017, 11:56 am
Thx Jimking
PostPosted: June 25th, 2017, 1:49 pm
I found this for now:
http://www.kuyuapp.com/xwidget/widgets/ ... 18/52.html
It's a Countdown Timer widget but for days only..
Send a pm to this guy and ask if he knows something..
http://kjc66.deviantart.com/
PostPosted: June 26th, 2017, 12:08 pm
thx and i will
PostPosted: June 27th, 2017, 11:39 pm
var Countdown = new function(mins, seconds, done) {
   this.timeLeft = mins * 60 + seconds;
   this.done = done;
Countdown.prototype.start = function () {
   var self = this;
   var down = function () {
       this.countdown--;
       if(self.timeLeft > 0) {
           self.counter = setTimeout(down, 1000);
       } else {
           self.done();
Countdown.prototype.pause = function () {
    if ( this.counter) {
        clearTimeout(this.counter);
Countdown.prototype.reset = function () {
    this.timeLeft = 0;
Use it like this:
// global
var c;
// in widget create
var c = new Countdown(minutes, seconds);
// on start
c.start();
// pause
c.pause();
//reset
c.reset();
// on stop
PostPosted: June 28th, 2017, 12:16 am
Steady on Digigamer, or people will start to use Xwidget for real javascript development!
PostPosted: June 28th, 2017, 10:11 am
Thx alot
it runs but how can i make a display for the counter to show numbers sorry for being a noob :)
PostPosted: June 28th, 2017, 10:22 am
Well dear chap, as this is a javascript engine it will be hard to answer your queries without some relation to javascript.
https://stackoverflow.com/questions/20618355/the-simplest-possible-javascript-countdown-timer
Digigamer's answer and the above link is the sort of answer you will receive here. Both replies would assist us. Bar us creating a widget for you your only recourse is to search through the widgets that exists in the gallery and look for one that fits, then look into making changes so it will do what you want.
PostPosted: June 28th, 2017, 10:27 am
ahh okay so i guess this is the wrong place to get help for understanding the script
sorry im a noob
PostPosted: June 28th, 2017, 11:34 am
No, its the right place but the trouble is the answers might be a bit complex for you to take.
Find a countdown widget, see how it is built and get used to the idea of Xwidget cores and how they operate, then look at some widgets with javascript and see if you can get a handle on how it does what it does, I have a stopwatch widget that might be interesting but it could also overwhelm you.
http://yereverluvinuncleber.deviantart.com/art/Panzer-Clock-and-Stopwatch-XWidget-593451692
This programming stuff isn't easy and even though javascript/Xwidgets is at the easiest end of it, it still requires knowledge of xwidget cores or javascript techniques.
Users browsing this forum: Google [Bot] and 95 guests
