PostPosted: May 11th, 2017, 7:23 am
Hello
Widget: countryside clock weather temperature, time, date, location works well, image exchange time and night does not see PC image even android.
Thanks in advance.
Kind regards.
PostPosted: May 11th, 2017, 10:54 am
Hello PKZ. I checked and the widget works fine on pc. No problem.
For the Android YES YOU'RE RIGHT! I forgot to assign the core for the images.. My bad! And all this time I had no reports for that. THANK YOU!
I fixed it and I also add the right click for the weather details.
Please delete it and download again from the app's gallery. :)
(keep in mind that the server requires some mins to overwrite the old file)
PostPosted: May 11th, 2017, 11:42 am
Hello jimking,
Successful PC and Android :D
Thank you
PostPosted: May 11th, 2017, 12:25 pm
You're welcome ;)
