 Post subject: Translation
PostPosted: March 26th, 2017, 9:51 pm
I'm french and i have downloading an widget. But all the information are in english and i search to translate in french.
Example :
I have Feel Like and i would have Ressentie.
How can i change this ?
Thanks for your answer
 Post subject: Re: Translation
PostPosted: March 27th, 2017, 2:31 am
Available languages:
Arabic
Bulgarian
Catalan
Croatian
Czech
Chinese-Simplified
Chinese-Traditional
Danish
Dutch
English
Estonian
Filipino
Finnish
French
German
Greek
Hebrew
Hindi
Hungarian
Indonesian
Italian
Japanese
Kazakh
Korean
Latvian
Lithuanian
Macedonian (Fyrom)
Malaysian
Norwegian
Polish
Portuguese
Portuguese (Brazil)
Romanian
Russian
Serbian
Slovak
Slovenian
Spanish
Swedish
Thai
Turkish
Ukrainian
Vietnamese
XWidget can show the menus/widgets in english OR system's language.
I personally use only the english language for the widgets to avoid text misalignments and bad visuals because some languages are not fully supported from all the fonts.
To change the language you need to edit the tag codes selecting the one without En
Example for date:
ENGLISH: ${MonthEn}
SYSTEM'S LANGUAGE: ${MonthTxt}
For the weather you can change the language through the settings. Same thing for the Android app:
viewtopic.php?f=23&t=5317
"I have Feel Like and i would have Ressentie."
For the texts like this as you can understand there is no way to auto-translate since are CUSTOM.
You need to "Edit" the widget (right click) and edit the "Text" field of the corrisponding component/text.
PostPosted: March 27th, 2017, 5:24 am
Many thanks for your answer
It's work
Users browsing this forum: No registered users and 85 guests
