 Post subject: Zooper Skin
PostPosted: May 29th, 2015, 4:16 pm
Saw this on XDA here: http://forum.xda-developers.com/showpost.php?p=61047394&postcount=849. This would be a nice one for one of the experts here to develop. I'm a novice, but if I had the weather images, I might give it a try. I would definitely download if someone developed this for XWidget (just the clock weather portion, not the whole screen). Have a good day.
 Post subject: Re: Zooper Skin
PostPosted: May 30th, 2015, 12:33 am
I will port it sbs8331. I have these icons, the clock images are from S6, so it will not be a problem... ;)
Edit:
About the first "zero" for the clock, I have to add it because there is no other way to make it work...
I can create manually create the 10,1112....etc for the 12h/24h clock, but the digits will look very "compressed" and ugly with 2 digits in space for one..
PostPosted: May 30th, 2015, 3:25 am
Done! :D
I will post the pc and android version really soon...
PostPosted: May 30th, 2015, 7:05 am
Great, thanks. One thing I might add is the location, but I can do that on mine when I download if you don't want to. No big deal. Much appreciated.
PostPosted: May 30th, 2015, 9:30 am
Yes I sure you can add it later.. ;)
PostPosted: May 30th, 2015, 11:30 am
posted to the official gallery :)
