 Post subject: Rotator and wind speed?
PostPosted: May 27th, 2015, 10:21 am
Is possible to make work properly a rotator with wind speed in km/h (0-45)..?
I tried to put directly the wind tag "${curWindSpeed}" to the rotator (changing the start/end points) , there is movement but shows false values.
PostPosted: May 28th, 2015, 9:02 am
try it...
You can reset any start and end angle for rotator1 and pie1 manually in the Designer. Rotator & pie will be show percent of wind speed from 0 to 45 km/h, regardless of the selected start and end angles.
wind_speed.xwp [7.03 KiB]
Downloaded 413 times
PostPosted: May 28th, 2015, 9:38 am
I will try and reply as soon as possible.. Thanks for your help! :)
