PostPosted: May 14th, 2015, 11:18 am
How to do color when day from sunrise to sunset?
Sunrise and sunset are variables parameters.
solar-time.xwp [22.1 KiB]
Downloaded 466 times
PostPosted: May 16th, 2015, 9:20 am
Can someone help me?
PostPosted: May 16th, 2015, 10:20 am
A quick thought is to use the "gradient" color at the component you use (roundline,pie)
Put a light yellow color for the start and a blue for the end.
Another idea is to create manually some images with various colors and assign the hours of the day, like I did here:
http://jimking.deviantart.com/art/Aweso ... -456130694
Now if you want something more complicated u will need script, so i can't help you in this part..
PostPosted: May 18th, 2015, 12:45 pm
I did it
