PostPosted: April 26th, 2015, 11:59 am
Some element of my widget have functions "panelOnMouseWheelUp" and "panelOnMouseWheelDown". I need if the menuitem is checked - functions work, if the menuitem is not checked - functions don't work.
PostPosted: April 27th, 2015, 10:19 am
can anyone help?
PostPosted: April 27th, 2015, 12:36 pm
Attach your. xwp please.. To understand what do you mean..
PostPosted: April 28th, 2015, 8:32 am
It's widget example.
exp01.xwp [6.56 KiB]
Downloaded 458 times
PostPosted: April 28th, 2015, 8:48 am
Need to be more clear Oletik.. The script for the un/checked menu works, butw what do you mean with "scroll"..? Because you put an image inside..Maybe you mean "slide"..?
PostPosted: April 29th, 2015, 9:06 am
Oh, it's my bad english...
As you have noticed, if rotate the mouse wheel the "image" move to up or down, but it must be only when the menu "on/off scroll" is checked. When the menu "on/off scroll" is not checked, if rotate the mouse wheel the image don't move.
PostPosted: April 29th, 2015, 1:00 pm
Hmm.. Now I understand. I will try to find the solution. @meme can find it in 5 mins though :)
PostPosted: April 29th, 2015, 7:37 pm
Modify to this..
function panelOnMouseWheelUp(Sender)
  if(menuitem1.checked)
  var PY = image.top;
  image.MoveTo( 75,PY+50,0.2,0,0,0,false)
function panelOnMouseWheelDown(Sender)
  var PY = image.top;
  image.MoveTo( 75,PY-50,0.2,0,0,0,false)
PostPosted: April 30th, 2015, 7:37 am
Thank you, It's what I wanted. But how to save in INI position "Image" where I stopped move it if I reload widget or restart computer?
PostPosted: May 1st, 2015, 12:07 am
Try this....
exp01.xwp [6.86 KiB]
Downloaded 394 times
PostPosted: May 2nd, 2015, 1:17 pm
Do others experience the annoyance that when using mouse wheel functions they do not work unless the widget has focus. :?:
By that I mean you must click on the widget before the mouse wheel function works, if you click away the widget loses focus and the mouse wheel functions do not work again until you click on the widget again. If so....
The first click can be avoided by adding
function widgetOnLoad()
  forceToFround();
All other clicks can be avoided by adding
function widgetOnEnter()
  forceToFround();
PostPosted: May 3rd, 2015, 7:57 am
Thank you very much for help, meme! I did all what I wanted!
