 Post subject: Magic Weather HD help
PostPosted: April 24th, 2015, 4:25 am
I am trying to get the weather text to go off focus when mouse is away from widget and on focus when I mouseover but can't see how to do this.
Using Magic Weather HD.
Any tips appreciated
Cheers, Pete
PostPosted: April 24th, 2015, 7:00 am
Here is an example:
http://jimking.deviantart.com/art/Windo ... -510361752
PostPosted: April 24th, 2015, 7:05 am
Thanks Jim, I just got it after many hrs!
I set binding tooltip control to layer1 which had all my weather infos grouped together.
Phew.
I take it there aren't any instructions on usage anywhere. I did look around but no joy.
Cheers, Pete
PostPosted: April 24th, 2015, 7:13 am
The best way is to find ready widgets to use the function you want and check how it works! ;)
PostPosted: April 24th, 2015, 7:16 am
That's what I was doing and it still took me 2 hrs for that!
Did you make this software Jim?
Cheers, Pete
PostPosted: April 24th, 2015, 7:21 am
.....because it's amazing software
Cheers, Pete
PostPosted: April 24th, 2015, 11:52 am
Nope! We have says thanks to Tony.
I make widgets, help with testing the Android app and the online galleries. :)
PostPosted: April 24th, 2015, 3:52 pm
Well your widgets are awesome and just shows what can be done.
great work Tony.
Is there any thread on the history of Xwidget?
How it came about? Tony's background etc?
I see this all started around 2011?
Cheers, Pete
PostPosted: April 25th, 2015, 1:12 am
Versions:
http://xwidget.com/ver.html
PostPosted: April 25th, 2015, 3:50 pm
Thanks Jim
Cheers, Pete
