 Post subject: Renaming Skins
PostPosted: April 20th, 2015, 3:50 pm
For skins downloaded to, and being modified on, my Android device, how can I change the name of the widget? I've modified a GS6 widget to look like Chronus and tried to rename the folder, but that didn't do the trick. I'd like to keep both widgets. Thanks.
 Post subject: Re: Renaming Skins
PostPosted: April 20th, 2015, 4:28 pm
You need to rename the widget 's name in the editor AND the widget' s folder (same name).
I do this through my pc and then I move it on my phone.
PostPosted: April 21st, 2015, 5:06 am
Got it. Thanks.
