PostPosted: February 26th, 2015, 6:07 am
sorre for my bad english-
All pictureframes with slideshow are buildet with a straight rontal view.
But I wish to place one frame at the sidewall at my wallpaper- a wall in a slanting perspective (angle).
So I like to transform the pictureframe widget also-
like this:
[img][IMG]http://fs2.directupload.net/images/150226/temp/4o7w9d5d.jpg[/img][/img]
Is this possible, maybe in the edit o the widget?
Best regards
Mike
PostPosted: February 26th, 2015, 6:16 am
Hi Mike. You mean to change the way of the wallpaper is shown on your desktop, after you use the "set as wallpaper" option?
PostPosted: February 26th, 2015, 6:26 am
the wallpaper is settet like my picture and I like to place a pictureviewer at this wall (above of one picture), but all viewers are in frontal view so i like to transform the viewer like the wall (like trapez but I need only one corner- bottom left).
It´s hard to translate my prob into english, sorry, I will do it better in german, smile)
PostPosted: February 26th, 2015, 6:39 am
If you mean how you can change the visual of the pictures creating a photo album widget, you need to change the "WrapMode" under the picture's Attributes tab of the editor.
The editor can't create 3d irregular pictures /frames though.
Except create a 3d frame and use the "Mask" option /trick.
Check this for example
http://jimking.deviantart.com/art/XWidg ... -418358278
PostPosted: February 26th, 2015, 7:17 am
Please look for maybe much better understanding my problem
http://www.directupload.net/file/d/3910/ptzx9i6h_jpg.htm
PostPosted: February 26th, 2015, 7:24 am
your example is exactly what I mean- the both sidely frames left and right.
How can I transform a normal viewer (frontal view) in a Viewer like the left or right frame in your example?
PostPosted: February 26th, 2015, 7:29 am
As I see you used one of my frame widgets. :)
I understand what do you want to do!
You need to create a 3d frame and use the "Mask" option /trick.
That's why I told you to check my 3d frame widget. ;)
There is no direct way to change a 2D widget in 3D! I created like this..
You need to create a new 3d widget according my example.
PostPosted: February 26th, 2015, 7:41 am
Yes, and some more of your work- you are a great artist!!
Thanks for your answer and your idea- I haven´t use the editor befor, just download and place the widgets. I know and use xwidget since two days...
Is it complicate to do this, do I need a lot of skills for this or do you have maybe an easy " ten step tutorial " to do this byself?
PostPosted: February 26th, 2015, 8:00 am
You're welcome Mike. :)
Please check these sections:
viewforum.php?f=10
viewforum.php?f=7
viewforum.php?f=8
where you can find tutorials and a lot of help/informations/assistance about the widgets and XW in general.
The best way though, is to check/edit the posted widgets and learn step by step the editor and how the things work , like I did.. ;)
After a while you will see that it's easy and you will create great widgets!
PostPosted: February 26th, 2015, 8:16 am
Thanks a lot, Dimitris.
It looks like a lot of time is needed for this- normaly I dont like to create my own widgets because there are a lot of very beautiful, ready to work widgets in the net-like yours:-)
It was only this one widget wich will make me happy forever... but to study the completly engine just to change the oilfilter is to hard, smile.
Maybe there will be a lot of interest for my idea- and maybe you will do this sometimes... one for the left wall and one for the right wall, both with two flexible corners on the right side to fit them in any ankle...
If so, please tell me and I will spend a donation- for me it´s worth a tribut for your work!
Thank you for your help and wasting your time with me- best regards to Italy from Germany
yours
Mike
PostPosted: February 26th, 2015, 10:13 am
Maybe I can use my previous 3D Frame widget as base and create the two widgets that you're talking about more easily.
All my widgets are for free. So no need to send me a donation. Thank you very much for your thought though! :)
I'm a little busy this period with the port of some widgets to Android, but I will try to fill your request as soon as possible...
I will send you a pm when they will be ready... So keep in touch!
Cheers
PostPosted: February 26th, 2015, 10:27 am
This will be much more than great!
