PostPosted: February 13th, 2015, 2:25 am
I would like to create an alternative version of my "Animated Weather HD" widget:
http://jimking.deviantart.com/art/Anima ... -495187763
I was thinking to add 5 more weather icons below (forecast) with the same function/animation/modes
But I'm not so sure how exactly I have edit the script, so all the components will have the same behavour..
The original script is this (made by @hamid)
//Script Author: Hamid ;
var oldweather;
function widgetOnLoad()
   Startingup=true
   AnimLoopMenu.Checked=GetIni("AnimLoop",0)
   AnimLoopMenuOnClick(AnimLoopMenu)
   Startingup=false
function accweathercore1OnUpdate(Sender)
   var weathertmp=accweathercore1.get("${curWeatherIcon}")
   if(weathertmp!=oldweather)
      oldweather=weathertmp
      WeatherObj.Src=""
      var listtmp=""
      var imgtmp=GetFileList(WidgetPath+"Images\\"+weathertmp,"png",0).split("|")
      for(var j=1;j<imgtmp.length;j++)
         listtmp+="Images\\"+weathertmp+"\\"+j+".png"+"|"
      listtmp+="Images\\"+weathertmp+"\\"+imgtmp.length+".png"
      WeatherObj.Src=listtmp
      StartAnimating(WeatherObj)
function StartAnimating(Sender)
   Sender.Play=0
   Sender.FrameIndex=0
   Sender.Play=1
function AnimLoopMenuOnClick(Sender)
   if(!Startingup)
      Sender.Checked=!Sender.Checked
      SetIni("AnimLoop",Sender.Checked)
      SaveIni()
   if(Sender.Checked)
      WeatherObj.LoopCount=0
   else
      WeatherObj.LoopCount=1
Thanks in advance... :)
Users browsing this forum: No registered users and 82 guests
