 Post subject: Edit script
PostPosted: January 23rd, 2015, 3:47 am
I would like to create a similar widget like this:
http://jimking.deviantart.com/art/Proce ... -378444183
The fact is that for this widget I used a single .png image for the rotation and this script.
var cs = 0;
function cpucore1OnUpdate(Sender)
  cs = cpucore1.get("%Percent");
  if(cs==0)
    pnganimate1.play = false;
    pnganimate1.rotateAngle = 0;
  else  if(cs<=30)
    pnganimate1.RotateAngleStep = Math.round(cs/2);
    pnganimate1.Play = true;
  else
//    print("Max = 17 !");
    pnganimate1.RotateAngleStep = 17;
Now I'll use a multiple serial png images (0-7). How the script should be edited to work properly...?
 Post subject: Re: Edit script
PostPosted: January 29th, 2015, 11:29 am
Please send me the widget, what you have so far, so I can see.
PostPosted: January 30th, 2015, 1:35 am
Here is the widget meme:
Thanks! :)
(the script is from the other widget)
Download and try this one to see what I mean, and how the new widget should work
cpu_cooler_resources.xwp [422.5 KiB]
Downloaded 547 times
PostPosted: January 30th, 2015, 2:40 am
Replace existing code with this, adjust the 100 value to alter the speed range.
Possibly set a minimum speed after the else rather than have the fan stop ?
var cs = 0;
    if(cs>0)
    pnganimate1.Interval = Math.round(100/cs);       //interval range 10~99999ms
   else
    pnganimate1.Play = false;
PostPosted: January 30th, 2015, 3:05 am
Yes! Is exactly what I was thinking about it. If you notice on the other widget, the fan doesn't stop even on low cpu usage (0%) and the fan movement is more fluid..
So if you can do it to this one, it will be the ideal! :)
PostPosted: January 30th, 2015, 12:35 pm
Try this, again you can adjust the minimum speed value, ms = 100
Are you going to display the cpu% in the blue box at the front ?
var cs = 0; // cpu speed %
var ms = 100; // minimum fan speed value
if(cs>0)
pnganimate1.Interval = Math.round(ms/cs); // interval = 10~99999ms
else
pnganimate1.Interval = ms
PostPosted: January 30th, 2015, 12:55 pm
Thanks for the script mate! I will try it as soon as possible..
About the cpu percentage I don't know. Maybe I will add a right click option to show /hide it.
What do you think?
PostPosted: January 30th, 2015, 1:23 pm
I think it looks OK
PostPosted: January 31st, 2015, 12:29 am
I think so...! ;)
Thanks again meme
@meme, I tried your second scipt but the fan doesn't move at all... :?
The first script worked..
PostPosted: January 31st, 2015, 12:43 am
Strange... here is the widget with code, try this.
cpu_cooler_resources.xwp [422.6 KiB]
Downloaded 551 times
PostPosted: January 31st, 2015, 1:08 am
Strange because this one works fine!
Thanks :D
