 Post subject: checkbutton1.Checked
PostPosted: January 18th, 2015, 2:16 pm
Hey, im trying to make a tool bar with many tabs, im using CheckButtons ( easier to see which one is checked)
i was trying to improvise a script so when i press one (Checked) the others become unpressed (Unchecked)
this is what i did , but it doesnt work, can someone help me plz? Thanks in advance :)
function Check1(Sender)
checkbutton1.Checked = true;
checkbutton2.Checked = false;
checkbutton3.Checked = false;
function Check2(Sender)
checkbutton1.Checked = false;
checkbutton2.Checked = true;
function Check3(Sender)
checkbutton3.Checked = true;
-George Carlin
 Post subject: Re: checkbutton1.Checked
PostPosted: January 18th, 2015, 7:49 pm
Tested this code for three checkboxes, works OK, please post your widget if you need more assistance.
function checkbutton1OnClick(Sender)
function checkbutton2OnClick(Sender)
function checkbutton3OnClick(Sender)
Users browsing this forum: No registered users and 82 guests
