 Post subject: Supress Right-Click Menu
PostPosted: November 11th, 2014, 7:29 am
Hello.
Is there any chance to suppress the right-click (on Widget) menu?
But still allow left-clicks? (so mouse-through is not an option)
Thanks for your insight!
-yinas
-- TheYinas --
on DeviantArt: http://yinas.deviantart.com/
PostPosted: November 11th, 2014, 7:49 am
I never use it but check if this is what you want:
- Right click on XW icon tray -> Options
- Under "Other" tab select "Disable all widgets Pop-up menu".
Please check better the program's menu before open a topic.
Thank u
PostPosted: November 11th, 2014, 7:56 am
ok maybe i should not open any topics anymore at all.
as you can see, i have built quite the functionality into my first (!) widget. without asking about anything beforehand.
my main computer broke down yesterday, so i can not develop anything, from photos to apps, nor continue working on my widget(s).
but it's fine, if you are annoyed by me trying to be productive and asking about (possibly difficult) solutions before going from idea>design to implementation stage,
i understand, and will refrain.
thankyouverymuchandhaveaniceday
-- TheYinas --
PostPosted: November 11th, 2014, 8:42 am
Maybe you didn't understand very well the meaning of my words. I didn't tell you that you can't ask for help here! This section is for this after all. I only SUGGEST you, before open a new topic navigate through the program's menus. And if you still have difficulties to find something, then the people here can help you. But since your pc broke down you can't even check the options.. So maybe it will be better for you have a working pc so you can check in real time our replies.
Also you can check this section for further help:
viewforum.php?f=10
PostPosted: November 11th, 2014, 9:23 am
yeah well sorry, thats how it sounded...
yes it would be better to have a working pc :/
right now i am on an old laptop to access forums like this properly, and collect my design thoughts...
-- TheYinas --
PostPosted: November 11th, 2014, 9:43 am
I'm glad that you understand my thoughts... I hope that you can use your pc again soon and share your widgets. :)
PostPosted: November 11th, 2014, 3:38 pm
I second this question - I've tried fiddling about in script and settings to suppress the popup menu on a particular element where I want the right click to perform a different function. e.g. I might want a digit to be left click to increase, right click to decrease. But right click always brings up the popup menu.
Any way to disable the menu for particular elements?
PostPosted: November 11th, 2014, 5:13 pm
i have the same idea before,
but i don't remember what i did before,
for now, i can only think of sending esc key to widget after popup menu,
to close the menu right after it shown,
maybe not the best way but think of it as a temporary solution
example:
var wsc=new ActiveXObject("WScript.Shell")
function widgetOnPopupMenu()
   widget.ForceToFround()
   wsc.SendKeys("{Esc}")
   setTimeout("sendthekey",100)
function sendthekey()
explanations:
1. first it will create an activex object
2. i have used ForceToFround() to make the widget in focus, to prevent sending key to another program incorrectly
3. SendKeys() will send the key to the program in focus (it will simulate the key press by activex object)
4. i have sent key 2times to prevent any possibility of the menu occurance
5. i have used settimeout() to do the 2nd sendkey() with delay of 100ms
Note:
don't forget to link the widgetOnPopupMenu() function to its Event
