 Post subject: Lock Widget Position
PostPosted: November 11th, 2014, 1:13 am
Hello.
Is it possible to lock the widget position via code?
My purpose would be to have a lock/unlock button for the user to click to lock/unlock the widget (or a certain element).
I couldn't seem to find it via code so far...
Thanks for your help!
-yinas
-- TheYinas --
on DeviantArt: http://yinas.deviantart.com/
 Post subject: Re: Lock Widget Position
PostPosted: November 11th, 2014, 5:16 am
The XW has a default right click option to lock a single widget or all together.
So I don't see the meaning of creating a widget/button like this...
Now if you still want this you need to wait for a reply for the users who know more about js code.
PostPosted: November 11th, 2014, 6:53 am
widget.LockPosition=1  //widget's lockposition will be enabled
widget.LockPosition=0  //widget's lockposition will be disabled
widget.LockPosition=!widget.LockPosition  //will toggle widget's lockposition
Note:
if you want to change the button's image accordingly, better to use if..else instead of above toggling,
since it can get unsync,
example:
if(widget.LockPosition)
image1.Src="enable.png"
else
image1.Src="disable.png"
PostPosted: November 11th, 2014, 6:56 am
hamid wrote:
thank you Hamid, will try it out soon.
.... i thought i tried this one before already <_< *me fail*
-- TheYinas --
PostPosted: November 11th, 2014, 11:23 am
Great reply hamid :)
