 Post subject: zte weather widget
PostPosted: November 5th, 2014, 5:37 am
can anyone make this widget pls
this is the link for weather apk
http://www.mediafire.com/download/2s9pm1b2o4ulw8e/WeatherClock.apk
 Post subject: Re: zte weather widget
PostPosted: November 5th, 2014, 5:57 am
Great widget. I will try to make it today! ;)
Thanks for the .apk..
I will post it here, in my DA gallery and in Android official XW gallery.
So, keep in touch!
By the way can you help me finding these weather widgets from ZTE..?
1)http://rootzwiki.com/news/take-a-memo-zte-announces-the-worlds-first-update-not-snapdragon-800-phone-update-zte-posted-misleading-specs/
(check the screenshots lower on page)
I'm looking for this "3D" weather widget with the cubes..
2) ZTE Era or ZTE Blade 3 (I don't know)
http://www.play.com/Mobiles/Mobile/4-/2 ... oduct.html
http://www.techarena.it/mwc-2012-zte-sv ... tile-17965
PostPosted: November 5th, 2014, 5:40 pm
@raththaran here is the widget (and two more from ZTE) ;)
I did my best...
viewtopic.php?f=11&t=5210
viewtopic.php?f=11&t=5211
viewtopic.php?f=11&t=5212
PostPosted: November 5th, 2014, 7:41 pm
great work bro......you're the man.....pls add this soon for android..
i'll try my best to find the others..
PostPosted: November 6th, 2014, 1:59 am
You're welcome. :)
Today I will post them in the Android gallery!
PostPosted: November 6th, 2014, 3:31 am
FIX: I fixed some bad tags/codes.
PLEASE DOWNLOAD AGAIN!!!
viewtopic.php?f=11&t=5210&p=10460#p10460
