PostPosted: October 15th, 2014, 3:22 pm
How can Xwidgets talk to each other? Is there a built-in method of relaying information from one Xwidget to another?
On some widget engines, the widgets have a method for passing information through a tellwidget() function or similar. This allows you to set up a listening routine on the target widget. Has anyone done this? I'll need this functionality for one of my widgets to work with others.
Last edited by yereverluvinuncleber on October 18th, 2014, 6:06 am, edited 1 time in total.
PostPosted: October 17th, 2014, 5:11 pm
Messages - example
// In the sender widget use this code from the button click to close all widgets
function button1OnClick(Sender)
msg("close","receiver");
// add extra lines replacing "receiver" with the name of the widgets you wish to close
// In the widget you wish to close add this code
function widgetOnMsg(MsgString)
if(MsgString=="close")
widget.close
Dont forget in the widget you wish to close to set the function
OnMsg = widgetOnMsg
so the code runs when a message is received
Topic here http://bbs.xwidget.com/viewtopic.php?f=8&t=3621
PostPosted: October 18th, 2014, 3:26 am
Very good Meme, very useful, thanks! A very useful function and I'm glad Xwidget has it. Marked as CLOSED.
