PostPosted: October 11th, 2014, 11:28 pm
Pls some one tell me how to use !SetWallpaper function to set any image as a wallpaper in "fit" or *stretch* mode.. they set in *fill* mode by default.
PostPosted: October 12th, 2014, 1:32 am
I think it's not possible (except I'm missing something) and you need to wait the next version of XW. It's actually a very good request/idea..
PostPosted: October 17th, 2014, 6:59 pm
you can use these commands in code:
SetWallpaper("filename.ext") //it will use last used mode for styling
SetWallPaper2("filename.ext",StyleNumber) //you should set a style by using a number
i don't know style numbers correctly, but i have tested these and they works:
example:
SetWallpaper("image1.jpg") //sets wallpaper and uses previous StyleMode
SetWallPaper2("image1.jpg",0) //sets wallpaper and makes it Center
SetWallPaper2("image1.jpg",1) //sets wallpaper and makes it Tile
SetWallPaper2("image1.jpg",2) //sets wallpaper and makes it Stretch
