PostPosted: October 3rd, 2014, 3:37 pm
Hi.
Please, can you help me with create widget for showing current currency?
Like this gadget (for windows)
http://www.sevengadgets.ru/other/344-in ... rovki.html
PostPosted: October 3rd, 2014, 4:19 pm
Hi MSPro.. This is really hard to create. We need comunication with a website and the chart doesn't support online functions like this..
PostPosted: October 3rd, 2014, 4:51 pm
if you can find which url it will connect to retrieve data,
then you can use downloadfile() function for it,and parse the downloaded data as you like,
and for the chart, you can check if it uses a image url for it,
if so, then you can load the chart as image
PostPosted: October 3rd, 2014, 6:08 pm
If it is values you are after you can use the Webpraser core with RegExp to get the values directly from the webpage,
the values are assigned to StringIndex1 tags that can be used how ever you like, text, chart or in code.
