PostPosted: September 18th, 2014, 3:00 am
I would like to ask if there is a script that can do the same job as a "pnganimate" object with the single continuous rotation (360o)
and the most important if with this this way the widget will use less cpu....
PostPosted: September 18th, 2014, 8:12 am
i think we have used it in some other project (player's disc rotation),
in the script we can change the:
1. how soon the change happens
2. how far it goes in each execution
it can change cpu usage a bit,
but i don't think it would be a noticable difference in cpu usage,
the most important thing that can change the cpu usage is the size of the drawing,
moving of the large drawings will use more cpu for drawing
PostPosted: September 18th, 2014, 8:22 am
You're right! The disc rotation for the "Clean Player" widget.
I have already noticed that the image size is maybe the most important for the cpu...
Was just a generic question... Thanks
