 Post subject: Removal of extra zero
PostPosted: September 8th, 2014, 1:13 pm
Hi everyone,
Just wondering how do I remove the extra 0 in clock. For example instead of the time reading 02:30, I want it to read 2:30. Thanks for your help
PostPosted: September 8th, 2014, 1:48 pm
Simple! Just select this tag "${Time}" instead of "${Time0}".
PostPosted: September 8th, 2014, 1:56 pm
I'm sorry but I'm new at this. Is this listed under Objects, Attributes, or Others? I'm editing it on my Android:?:
PostPosted: September 8th, 2014, 3:06 pm
I always create/edit all the widgets on pc. And connecting the phone with usb you can modify your widget in real-time checking immediately the results on your phone's screen.
Anyway.. On the phone: Touch on the widget and select "Edit". Then:
1) Touch/select the object you want to edit on "Objects" tab. The "clock" txt for example.
2) Go on "Attributes" and select "Bind Core" and "Core label". There just delete the "0" from the "${Time0}" and press OK.
3) Exit and press save
PostPosted: September 9th, 2014, 1:07 am
Thank you very much :D
PostPosted: September 9th, 2014, 1:17 am
You're welcome! :)
