 Post subject: alarm animes
PostPosted: August 31st, 2014, 6:04 am
hello would like to create an alarm clock to give me notifications from week to week to remind me of episodes of anime that leaves example, every tuesday one piece, Toriko every Thursday, Saturday zankyou no terror, all these warnings in an alarm only, someone have something there? 'm new to XWidget not have notion of creating know it works with a code but do not know where to start or how to know if you have to create something like I said there could download a similar program but I want to put a skin anime Image
That was the only thing I could do in the program tried to put html and pull only the data of the episodes but gave up is very difficult,
 Post subject: Re: alarm animes
PostPosted: August 31st, 2014, 10:15 am
Topic moved in the right section...
PostPosted: August 31st, 2014, 4:47 pm
can you add the widget for it, i will do the coding
html object have a little bug,
as you explained above, i don't think it needs html to do this
