PostPosted: July 29th, 2014, 2:45 am
Guys I have a pnganimate object. It starts on mouse enter, but I need the script so with mouse leave will make the inverse movement.
Like a box that opens and closes..
I can't remember if I already use it in one of my widgets..
Thanks in advance!
PostPosted: July 30th, 2014, 1:22 pm
do you mean this way?
function pnganimate1OnMouseEnter(Sender)
  Sender.Inverse=0
  Sender.Play=1
function pnganimate1OnMouseLeave(Sender)
  Sender.Inverse=1
  Sender.Play=1
PostPosted: July 30th, 2014, 3:31 pm
I'll test it tomorrow but from what I see, should work ok!
