 Post subject: Widgets doesnt run !?
PostPosted: July 11th, 2014, 9:59 am
Hey guys, i have a problem. When i download new widget and click to open, nothing happens. Then when i click again, it says that the widget is already running, but i cant see it or find it. Some ideas !?
PostPosted: July 11th, 2014, 10:50 am
Widget opens with the background. Look at the bottom bar of windows. Click the right mouse button and add the widget. :)
PostPosted: July 11th, 2014, 11:11 am
You can check the running widgets double clicking on the icon tray, and select "Manage Widgets".
Also some times you need to press "Refresh Widgets list" (right click option when you have the installed widgets bottom bar open)
pm: Also you need to check if you selected the "Hide" right click option. The widget runs in the background and is visible only in "Dashboard"/F12 mode.
