Post new topic Reply to topic  [ 24 posts ]
PostPosted: July 10th, 2014, 1:48 am
I have 9 pngs water drop images, and I would like to make a "swim" full screen widget.
QUESTIONS:
1) Is possible using the "swim" widget's optionto make the drops going only from up to down and in a steady vertical position like in real life..?
2) Can we combine all the 9 images so they will appear randomly..?
Thank you!
drops.zip [34.62 KiB]
Downloaded 648 times
PostPosted: July 10th, 2014, 2:22 am
I think it will be better to attach them into a slider and make a full screen widget.
I went through the docs, but couldn't find anything about swim direction
PostPosted: July 10th, 2014, 4:42 am
Hi DG! Thanks for the quick reply..
The fact is that with the widget->"swim" option as you know the images floating randomly. I'm almost sure that should be a way to control the movement though script, but as it seems from my topic here I don't know how.. :)
PostPosted: July 10th, 2014, 11:02 am
with [widget>swim], whole widget will floating on screen, not only images;
this means all images get floated together
for [widget>swim], the only option that i found is to control [OnSwimToLeft] event and [OnSwimToRight] event
there is a way to make it possible to swim only one direction for left/right, not up/down
can you explain more how you want the images to be shown?
PostPosted: July 10th, 2014, 12:08 pm
Hi hamid!
If you check my attach file you will see that are 9 different water drop images like this one:
So I was thinking to make a full screen images where the drops will fall from top to bottom like a rain effect on screen!
Imagine like a "swim" widget (without use the "keep on screen" swim option), but the images will move only in a vertical random position.
The best of course is to have also random the start point of the drop. Other will start fall from the top, other from the middle..
Just think a rain effect on the screen.. :)
PostPosted: July 10th, 2014, 12:42 pm
couldn't imagine this with swim effect
maybe you want it to create wind
but why don't you create a png animation or a gif?
PostPosted: July 10th, 2014, 1:27 pm
I told you practically I can create 9 animated pngs with the fall animation..
But we can make their appearance ramdom on screen..?
(I was thinking the swim option to give you an idea about how it will look..)
This is the question..If is possible to control their movement though script..
PostPosted: July 10th, 2014, 1:38 pm
for the fall animation, we can also use progressbar:
raindrop_[test1] [2014.05.07].xwp [41.81 KiB]
Downloaded 685 times
but i think creating animation file is better
maybe it uses less resources
if you create animation file for each of the images, then it can be done
randomizing will be done like the broken screen widget
edit1:
Note:
in above attachment i have rotated the images to be used on up-to-down progressbar
edit2:
i don't know why i used progressbar for this
we can use image object for this without rotating image:
raindrop_[test2] [2014.05.07].xwp [41.13 KiB]
Downloaded 690 times
but still i think creating animation file will be better
PostPosted: July 10th, 2014, 2:38 pm
Both test files are great!! :)
How about the control of the fall speed...?
It's not so hard but surely requires some time..
I'm really curious to see which of the two modes use less resources..
Since it will cover all the screen's height (x768) and the number of the pngs will be high, maybe the anim png is worst..
But I need to test it first..
PostPosted: July 10th, 2014, 4:20 pm
here's with more images,
but doesn't added random image
raindrop_[test3] [2014.07.11].xwp [41.47 KiB]
Downloaded 722 times
i think cpu usage is high for it
plz test it
fall speed can be set using:
1. image position increment, ex: image1.Top+=12
2. setTimeout execution time, ex: setTimeout("Rainfall",20)
PostPosted: July 10th, 2014, 4:59 pm
Testing your last file "raindrop_[test3] [2014.07.11].xwp" the cpu usage is 0~2%!! :D
I will make some more tests decreasing the speed and adding the various pngs and I'll reply as soon as possible...
PostPosted: July 11th, 2014, 2:12 am
I made some little changes to the script and edited the scale % of some images to be more realistic..
Cpu usage=0%
Next steps:
- Randomize their movement on x-axis? <- ->
- (more complicated) With mouse click appear of a random water drop (like the "Broken Screen")
I try to study the script from the "Broken Screen" widget and copy the function but is a bit confusing for me...
raindrop_[test4].xwp [41.49 KiB]
Downloaded 781 times
PostPosted: July 11th, 2014, 5:10 am
Cpu usage=0%
Cpu Usage will be different on different PCs
mine is also 0
but you can see usage better on a graph
it's not high, but i think it shouldn't be this for a widget (that will be always running)
can you create a gif or png animation to test it with that?
and why don't you use animation effect (like your rocket_recycle_bin widget)?
i'm not so familiar with animation effects of xwidget, so i can't use it myself
why should it move on x-axis?
their speed make me imagine it as water-drops, not raindrops
are they going to be water-drops?
then why they should move on x-axis?
do you mean zigzag?
can you show the movement in an image?
1. should it start from click position?
2. do you mean random image files? they are not so different in shape
PostPosted: July 11th, 2014, 6:51 am
do you mean zigzag?
I was thinking more like raindrops.. (But even as a water-drops the water falls randomly..)
I mean that their vertical position will change. They will drop from a random left/right position.
For now, each drop keeps the same x-asis position. (up&down movement in a steady x-asis)
1. Yes (double click is better)
2. I know.. Not all but maybe 2-3 different images..
I can do it but it needs time.. I have to create a transparent image with GIMP with 768 height resolution as my laptop.
Image that I have to start from top, and using the keyboard move it lower and lower, and save each image.. I think that we will need +200png images for each kind of drop!!! :!:
Since is working fine with your own way, the cpu is ~0%, why do all this work...
PostPosted: July 11th, 2014, 7:03 am
i just found how to use animation effects of xwidget for images
but really doesn't useful
it uses very high Cpu usage (about 50% of mine)
so using the code is better for now
i have added the code for disable widget when it's hide
this way we could make lower cpu usage when it's hidden
2. I know.. Maybe 2-3 different images..
ok, now i'm working on it
PostPosted: July 11th, 2014, 7:43 am
Ok thanks! I'm waiting for the "test5"... :)
Yes I know.. These switch/animations option are almost useless. You need a certain design, size and function to use them with low cpu.
One thing that I wish for the v2.0 of XW is low consumption for the effects..
PostPosted: July 11th, 2014, 1:57 pm
ok, it's ready:
raindrop_[test5] [2014.07.12].xwp [37.72 KiB]
Downloaded 666 times
Changes:
Added: Disabling/Enabling on Hide/Show to save Cpu Usage when it's Hidden
Added: MenuItem to Clear Screen
Added: MenuItem to Set Number of images
Added: Code to automatically create imageObjects
Added: Code for Random ImageFile Usage
Added: Code for Random Speed, Position for each Object
Added: Widget LockPosition and MouseThrough
Removed: Extra ImageObjects from widget
Note:
-Adding more than 10 ImageObjects will cause cpu usage go high
(for me getting 20-30%)
PostPosted: July 11th, 2014, 3:00 pm
Visualy is reallly GREAT! And your script is rock!
But I can't activate the right click option or click on the widget(move).. :?
Maybe of this "Added: Widget LockPosition and MouseThrough"...?
PostPosted: July 11th, 2014, 3:31 pm
yes, it' MouseThrough
you can activate widget by pressing Ctrl button
same way as BrokenScreen widget
Note:
also if you add about 100 imgObjects, RightClick Menu of widget and even Click on widget may not work
this is because of high cpu usage
PostPosted: July 11th, 2014, 3:35 pm
Yes you're right.. I forgot it!
also if you add about 100 imgObjects RightClick Menu and even Click of mouse may not work
Yes it's logical. I will keep it in mind..
Excellent work as always bro! ;)
PostPosted: July 11th, 2014, 6:17 pm
Here's the new version:
raindrop_[test6] [2014.07.12].xwp [37.92 KiB]
Downloaded 694 times
Changes:
Added: Cleaner Code and Menuitem to clean the drops on mouseenter
Added: the Mouse Cursor for Cleaner
fixed: Saveini() have been missed in previous code,
-> i don't know how it works without it, maybe it doesn't require anymore,
-> but i added it for compatibility with old versions
PostPosted: July 12th, 2014, 12:58 am
Changes:
Great addition! 8-)
I think is ready now. We're or better YOU did it..!
PostPosted: July 12th, 2014, 7:20 am
i have added some additional things
i think this is the final work on this
here's new version:
raindrop_[test7] [2014.07.12].xwp [38.13 KiB]
Downloaded 646 times
Changes:
Added: Enable Counter Menuitem and code to count the number of items
Added: Some Optimization to Code to make it easier to read
Added: Producer Info to the script code's Comment
PostPosted: July 12th, 2014, 8:40 am
Nice!! I will edit the "Widget icon" image and I will post it later..
Thanks a bunch bro!
Posted: :D
viewtopic.php?f=11&t=4745
