It is currently October 23rd, 2026, 5:39 am
 Post subject: Weather Update Interval
PostPosted: July 3rd, 2014, 9:58 am
What is the difference between these settings? Which of them is the priority?
Inside XDesigner
and
PostPosted: July 10th, 2014, 1:43 am
Are actually the same thing. The second option is as a shortcut. When you use a widget you don't need to open the designer!
PostPosted: July 10th, 2014, 3:58 am
Thanks.
