PostPosted: May 17th, 2014, 6:49 am
The Weather Details screen has some icons in it that I can't seem to find in my installation. Icons such as:
  • Umbrella (this is the one I'm most interested in)
  • Wind
  • Thermometer
  • Humidity
I found all the weather icons (C:\Program Files (x86)\XWidget\Res\Images\weather_icons), but I can't seem to find the Umbrella, etc.
Any help is appreciated!
PostPosted: May 17th, 2014, 9:20 am
No need to search for these in the program's folder. Though google images you can find almost all the pngs you want!
To make the things more simple for you check this and you will find what you're looking for in the widget's folder.. ;)
http://jimking.deviantart.com/art/Gloss ... -450337765
PostPosted: May 17th, 2014, 9:44 am
That's great--thank you! :) I'm also trying out some icon fonts from IcoMoon (which I've used in the past for websites):
http://icomoon.io/
