 Post subject: Solar Hijri Calendar
PostPosted: May 4th, 2014, 9:36 am
Hi there
I don't know anything about xwidget coding.
But I would like to know if anyone can show me a way to show solar calendar.
 Post subject: Re: Solar Hijri Calendar
PostPosted: May 5th, 2014, 12:01 am
Do you mean this calendar?
What XWidget uses is gregorian calendar, which is also a solar calendar. Conversion between the two won't be difficult.
* Of course, showing a full calendar is much more difficult... nevertheless, we can show day,month,year,week etc easily.
PostPosted: May 5th, 2014, 1:43 am
Thanks
Would you show me how to change Graphic clock or iCal widget to show that?
Today is 05(dd)/05(mm)/2014(yyyy) in us and 15(dd)/02(mm)/1393(yyyy) in that calendar.
PostPosted: May 7th, 2014, 6:48 pm
No, unfortunately, I can't code the calendar-like interface using the scripting API.
However, I can display it as dd-mm-yyyy
Just give a link which one to modify? :)
PostPosted: May 7th, 2014, 9:26 pm
yeah
PostPosted: May 7th, 2014, 9:39 pm
origin code: http://farhadi.ir/projects/jalalijscalendar/
Solar_Hijri_Calendar.xwp [8.02 KiB]
Downloaded 413 times
