PostPosted: April 18th, 2014, 6:08 am
Can somebody help me with problem? How to write code to limit digits after comma for text which show result of some mathematical calculation? I have "1750,3333333333", I need "1750.33".
Thanks.
PostPosted: April 18th, 2014, 6:28 am
Topic moved to the right section. Please next time check better the section that you post.
PostPosted: April 18th, 2014, 7:01 am
var r = 100/3; //33.333333333
text1.text = r.toFixed(2); // 33.33
text2.text = r.toFixed(3); // 33.333
PostPosted: April 18th, 2014, 2:29 pm
For more info and examples checkout http://www.w3schools.com/jsref/jsref_tofixed.asp
PostPosted: April 19th, 2014, 7:41 am
Thank you very much for your help! It works OK
