PostPosted: February 24th, 2014, 4:46 pm
The widget is the BodClock3d and I would like to make it full colour customization:
function image1OnDblClick(Sender)
var color = selectColor(ampm.font.fill.color);
setcolor(color);
Setvalue("color",ampm.font.fill.color);
SaveIni();
function widgetOnLoad()
setcolor(GetValue("color",ampm.font.fill.color));
function setcolor(color)
hour.font.fill.color = color;
ampm.font.fill.color = color;
day.font.fill.color = color;
month.font.fill.color = color;
I would like to control/change the colour of two more components: "line" and "min".
How should be the additional script to have the same colour control (for these two other components "line" and "min")?
PostPosted: March 7th, 2014, 11:23 pm
just you need to add those components like others:
//new components:
line.font.fill.color = color;
min.font.fill.color = color;
PostPosted: March 8th, 2014, 6:18 am
Thanks for the reply hamid! But I can't find the right place to put your script, and the doudle click function/script doesn't support it..
could you pls take a look from the "inside", for check better what I want to do..
PostPosted: March 8th, 2014, 11:21 am
my old code would change the color of all components with one color
i rewrite the code to have 2 color selections
bobclockd3_original_test[2014.03.08].xwp [200.32 KiB]
Downloaded 354 times
PostPosted: March 8th, 2014, 3:02 pm
Now it's perfect! :D
Thanks for your precious help hamid!
PostPosted: March 8th, 2014, 3:53 pm
Posted: :)
viewtopic.php?f=11&t=4224
