 Post subject: Edit script
PostPosted: February 23rd, 2014, 9:29 am
Guys could you pls take a look at the scipt? It needs a little adjustment for make it work properly..
Is a simple "if" and "else" script for battery (%) and a certain pnganimate that should play on each x10%.
THANK YOU
 Post subject: Re: Edit script
PostPosted: March 9th, 2014, 2:04 pm
maximum allowed size for attachments is 5MB, so i have deleted the PNGimages from the package to reduce attachment size,
don't forget to add them again
and also how you post an attachment bigger than limit?
anyway, i have rewrite the script code and also made some changes to the gui
but i don't have any battery to test it out,
so plz test it and post the results
Changes:
1. renamed pnganimate Objects from [1..11] to [0..10]
2. added pngfiles list to the pnganimate0 object
3. rewrite whole script code
stickman_battery_animated_test1[2014.03.10].xwp [46.95 KiB]
Downloaded 356 times
PostPosted: March 9th, 2014, 2:22 pm
Thanks a lot hamid! I will test it and I will post the results! Lately I post widgets with size >5Mb. So I think that Tony or qiancang increased the limit..!
Have you tried to upload it? If you still have problems you can split it using .rar format.. ;)
(The first file that I posted here was >5Mb)
PostPosted: March 9th, 2014, 3:16 pm
Seems that is working fine.
Thanks again hamid! :)
PostPosted: March 19th, 2014, 2:22 am
jimking, if you are forum admin. you may be excluded from the upload limit.
PostPosted: March 19th, 2014, 3:56 am
Thanks for the promotion! (I'm a Mod) :lol:
For the upload limit this a generic modification of the server/php so normally this is common for all the users..
